Hi. I am facing very similar issues when trying to fully close my KNX shutters (in german: “Jalousie außen am Fenster”) within a HA scene. When activating the HA scene, the shutter only seems to tilt a single step. Like @paf mentioned, this is probably due to the fact that the “close” datagram is immediately followed by the “tilt” datagram. In contrast to @paf, I do not see any difference when removing current_tilt_position
line from the scenes.yaml. Please find below my reduced test setup.
Here is my KNX shutter config:
cover:
- name: "Arbeitszimmer Nordseite"
move_short_address: "2/0/80"
move_long_address: "2/0/81"
position_address: "2/0/82"
position_state_address: "2/0/83"
angle_address: "2/0/84"
angle_state_address: "2/0/85"
travelling_time_up: 25
travelling_time_down: 25
device_class: "shutter"
Creating a HA scene to fully close above shutter via UI (settings > scenes > new) results in the following scenes.yaml:
- id: '1684872983297'
entities:
cover.arbeitszimmer_nordseite:
current_position: 0
current_tilt_position: 0
device_class: shutter
friendly_name: Arbeitszimmer Nordseite
supported_features: 255
state: closed
metadata:
entity_only: true
icon: mdi:test-tube
When activating this scene via UI (settings > scenes > click … menu behind “Test”) these are the KNX logs:
2023-05-23 22:36:21.132 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.57" destination_address="2/0/81" payload="<GroupValueWrite value="<DPTBinary value="1" />" />" />
2023-05-23 22:36:21.132 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/81")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:36:21.134 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="24" cemi="1100bce011391051010081" />" />
2023-05-23 22:36:21.137 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100421000a04011800
2023-05-23 22:36:21.137 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="24" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:36:21.138 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100420001504016f002e00bce011391051010081
2023-05-23 22:36:21.138 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="111" cemi="2e00bce011391051010081" />" />
2023-05-23 22:36:21.138 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="111" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:36:21.150 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/81")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:36:21.198 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.57" destination_address="2/0/80" payload="<GroupValueWrite value="<DPTBinary value="1" />" />" />
2023-05-23 22:36:21.199 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:36:21.200 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="25" cemi="1100bce011391050010081" />" />
2023-05-23 22:36:21.203 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100421000a04011900
2023-05-23 22:36:21.203 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="25" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:36:21.205 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 061004200015040170002e00bce011391050010081
2023-05-23 22:36:21.205 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="112" cemi="2e00bce011391050010081" />" />
2023-05-23 22:36:21.206 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="112" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:36:21.206 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:36:21.469 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 061004200016040171002900bcd0110310550200800b
2023-05-23 22:36:21.469 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="113" cemi="2900bcd0110310550200800b" />" />
2023-05-23 22:36:21.469 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="113" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:36:21.471 DEBUG (MainThread) [xknx.cemi] Incoming CEMI: <CEMIFrame code="L_DATA_IND" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.3")" dst_addr="GroupAddress("2/0/85")" flags="1011110011010000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xb]" />" />")" />
2023-05-23 22:36:21.472 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.1.3" destination_address="2/0/85" payload="<GroupValueWrite value="<DPTArray value="[0xb]" />" />" />
When I manually remove current_tilt_position: 0
in scences.yaml and save, I get the exact same result:
2023-05-23 22:45:09.463 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.57" destination_address="2/0/81" payload="<GroupValueWrite value="<DPTBinary value="1" />" />" />
2023-05-23 22:45:09.464 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/81")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:45:09.468 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="29" cemi="1100bce011391051010081" />" />
2023-05-23 22:45:09.470 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100421000a04011d00
2023-05-23 22:45:09.470 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="29" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:45:09.470 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 061004200015040177002e00bce011391051010081
2023-05-23 22:45:09.470 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="119" cemi="2e00bce011391051010081" />" />
2023-05-23 22:45:09.471 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="119" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:45:09.476 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/81")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:45:09.522 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.57" destination_address="2/0/80" payload="<GroupValueWrite value="<DPTBinary value="1" />" />" />
2023-05-23 22:45:09.523 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:45:09.525 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="30" cemi="1100bce011391050010081" />" />
2023-05-23 22:45:09.527 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100421000a04011e00
2023-05-23 22:45:09.527 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="30" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:45:09.528 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 061004200015040178002e00bce011391050010081
2023-05-23 22:45:09.528 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="120" cemi="2e00bce011391050010081" />" />
2023-05-23 22:45:09.528 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="120" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:45:09.532 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-23 22:45:09.800 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 061004200016040179002900bcd0110310550200801e
2023-05-23 22:45:09.800 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="121" cemi="2900bcd0110310550200801e" />" />
2023-05-23 22:45:09.801 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="121" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-23 22:45:09.802 DEBUG (MainThread) [xknx.cemi] Incoming CEMI: <CEMIFrame code="L_DATA_IND" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.3")" dst_addr="GroupAddress("2/0/85")" flags="1011110011010000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x1e]" />" />")" />
2023-05-23 22:45:09.803 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.1.3" destination_address="2/0/85" payload="<GroupValueWrite value="<DPTArray value="[0x1e]" />" />" />
It was about 2 years ago when I configured all my KNX devices for HA. So far everything worked as expected in HA. This is the first time I use HA scenes.
I wonder if the group addresses used by the HA scene - first 2/0/81 (move_long_address = move to end) and second 2/0/80 (move_short_address = tilt one step) are correct?
I also wonder if device_class: shutter
is correct for “Jalousien”. Should it be device_class: blind
? The docs about “device class” are not clear to me. Does it make a difference at all, for scenes and in general? In fact, all my “Jalousien” are configured exactly like “Arbeitszimmer”. And even all my “Rollladen” are configured with device_class: shutter
like below. Is this a problem?
- name: "Schlafzimmer Südseite"
move_short_address: "2/1/88"
move_long_address: "2/1/89"
position_address: "2/1/90"
position_state_address: "2/1/91"
travelling_time_up: 19
travelling_time_down: 18
Last but not least, I noticed another strange behavior: Whenever I enter or exit the settings > scenes > “Test” UI, my shutter is tilting one step. Basically as if I activated the scene which I did not do.
This is the log when entering the “Test” scene UI:
2023-05-24 00:03:45.985 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.57" destination_address="2/0/81" payload="<GroupValueWrite value="<DPTBinary value="1" />" />" />
2023-05-24 00:03:45.985 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/81")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-24 00:03:45.990 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="100" cemi="1100bce011391051010081" />" />
2023-05-24 00:03:45.993 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100421000a04016400
2023-05-24 00:03:45.993 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="100" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:03:45.994 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100420001504014a002e00bce011391051010081
2023-05-24 00:03:45.994 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="74" cemi="2e00bce011391051010081" />" />
2023-05-24 00:03:45.994 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="74" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:03:46.012 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/81")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-24 00:03:46.060 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.57" destination_address="2/0/80" payload="<GroupValueWrite value="<DPTBinary value="1" />" />" />
2023-05-24 00:03:46.060 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-24 00:03:46.063 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="101" cemi="1100bce011391050010081" />" />
2023-05-24 00:03:46.066 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100421000a04016500
2023-05-24 00:03:46.066 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="101" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:03:46.067 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100420001504014b002e00bce011391050010081
2023-05-24 00:03:46.067 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="75" cemi="2e00bce011391050010081" />" />
2023-05-24 00:03:46.067 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="75" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:03:46.081 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="1" />" />")" />
2023-05-24 00:03:46.347 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100420001604014c002900bcd0110310550200800d
2023-05-24 00:03:46.348 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="76" cemi="2900bcd0110310550200800d" />" />
2023-05-24 00:03:46.348 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="76" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:03:46.350 DEBUG (MainThread) [xknx.cemi] Incoming CEMI: <CEMIFrame code="L_DATA_IND" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.3")" dst_addr="GroupAddress("2/0/85")" flags="1011110011010000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xd]" />" />")" />
2023-05-24 00:03:46.351 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.1.3" destination_address="2/0/85" payload="<GroupValueWrite value="<DPTArray value="[0xd]" />" />" />
This is the log when exiting the “Test” scene UI:
2023-05-24 00:04:28.967 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.57" destination_address="2/0/80" payload="<GroupValueWrite value="<DPTBinary value="0" />" />" />
2023-05-24 00:04:28.968 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="0" />" />")" />
2023-05-24 00:04:28.970 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="102" cemi="1100bce011391050010080" />" />
2023-05-24 00:04:28.975 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100421000a04016600
2023-05-24 00:04:28.975 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="102" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:04:28.975 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100420001504014d002e00bce011391050010080
2023-05-24 00:04:28.975 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="21" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="77" cemi="2e00bce011391050010080" />" />
2023-05-24 00:04:28.976 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="77" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:04:28.978 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.57")" dst_addr="GroupAddress("2/0/80")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTBinary value="0" />" />")" />
2023-05-24 00:04:29.314 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.178.8', 3671): 06100420001604014e002900bcd01103105502008000
2023-05-24 00:04:29.314 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="78" cemi="2900bcd01103105502008000" />" />
2023-05-24 00:04:29.314 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.178.8:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="78" status_code="ErrorCode.E_NO_ERROR" />" />
2023-05-24 00:04:29.319 DEBUG (MainThread) [xknx.cemi] Incoming CEMI: <CEMIFrame code="L_DATA_IND" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.3")" dst_addr="GroupAddress("2/0/85")" flags="1011110011010000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x0]" />" />")" />
2023-05-24 00:04:29.324 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.1.3" destination_address="2/0/85" payload="<GroupValueWrite value="<DPTArray value="[0x0]" />" />" />
Calling a script from a scene as mentioned by @paf is not possible (different concept). Using a KNX scene triggered from a HA scene as mentioned by @farmio might be an option but seems double effort to me.
I still hope to get the HA scenes via UI working with all my “Jalousien” and “Rolladen”. Any help would be appreciated.
Thanks.
