Schedule automation
Hi everybody, Im a newbe on HA. I try to make a controled heating on my house via NodeMcu + Relay + MQTT and HA and work fine. But now i need to make a Schedule for heating and I used automation, but I dont know how to make some scheduling for automation.
Could you please Help?
Hey - I’m in exactly the same situation. I have a target temperature set in HA which a generic_thermostat uses to switch the remote relay on or off. I’ve got some very simple automation in place right now:
automation:
  - alias: Reduce the target temperature overnight
    initial_state: True
    hide_entity: False
      platform: time
      minutes: '50'
    condition:
      condition: time
      after: '21:45:00'
      before: '06:00:00'
      service: climate.set_temperature
        temperature: 14
  - alias: Reset the target temperature
    initial_state: True
    hide_entity: True
      platform: time
      after: '06:00:00'
        temperature: 20.5
This is fine for hour by hour changes, but to do day schedules, you’ll need to add weekday conditions https://home-assistant.io/getting-started/scripts-conditions/#time-condition
Thank You for reply. So I only add
weekday:
  • mon atd…
I go to setup.
Just a tip:
don’t only use minutes: for the time trigger as that will fire every second within this minute.
Sebastian
Ah - gotcha. Good to know. So it should be:
  platform: time
  minutes: 50
  seconds: 0
to only trigger once, at 50 minutes and 0 seconds.
