Scheduled backup crashes HA
I have configured HA so my Backup is stored at Synology NAS.
It works OK when I make a manual backup.
But when I make a scheduled Backup the HA is messed up … at the side view Terminal / File editor / deCONZ … shows a blank page.
The only way to get HA back and running is a hardware restet and then it looks OK after booting.
Here is log from scheduled Backup:
Loggare: homeassistant.components.backup
Källa: components/backup/config.py:571
integration: Backup (dokumentation, ärenden)
Inträffade först: 07:30:30 (1 förekomst)
Senast loggade: 07:30:30
Error creating backup: Backup failed: [{'type': 'HomeAssistantBackupError', 'message': "Preparing backup of Home Assistant Core failed. Failed to inform HA Core: Unsuccessful websocket message - {'id': 1645, 'type': 'result', 'success': False, 'error': {'code': 'pre_backup_actions_failed', 'message': 'Error during pre-backup: Could not lock database within 30 seconds.'}}.", 'stage': 'home_assistant', 'error_key': None, 'extra_fields': None}]
  • raspi5
  • Installationsmetod Home Assistant OS
  • Core 2026.1.2
  • Supervisor 2026.01.1
  • Operating System 16.3
  • Användargränssnitt 20260107.2
Have you customised the Recorder in any way?
Have not used Recorder …
How much memory does your Raspberry 5 have?
How big is the database you are trying to lock and backup?
How busy is your processor? Normally, and especially around backup time?
SD Card or SSD? How big? How much free space? Any disk or I/O Errors in the system log?
Raspi5
16 GB
250GB PCIe NVMe SSD
Utilization:
CPU 1%
Disk 5%
Memory 7%
Size of backup file 28 MB
Total log file:
[core-ssh ~]$ ha core logs
/local/custom-lovelace/compact-custom-header/custom-header.js:617:37079
2026-01-17 11:40:37.286 ERROR (MainThread) [frontend.js.modern.202601071] Uncaught error from Chrome WebView 143.0.7499.192 on Android 16
Error: Failed to execute 'define' on 'CustomElementRegistry': the name "battery-state-card" has already been used with this registry
A.define (node_modules/@webcomponents/scoped-custom-element-registry/src/scoped-custom-element-registry.ts:180:12)
customElements.get (/maxwroc/battery-state-card/v3.2.1/src/index.ts:10:19)
customElements.get (/maxwroc/battery-state-card/v3.2.1/src/index.ts:21:17)
2026-01-17 12:53:50.021 ERROR (MainThread) [frontend.js.modern.202601071] Uncaught error from Chrome WebView 143.0.7499.192 on Android 16
TypeError: Cannot read properties of null (reading 'querySelector')
ha_elements (/local/custom-lovelace/compact-custom-header/custom-header.js:1:13663)
2026-01-17 12:53:50.566 ERROR (MainThread) [frontend.js.modern.202601071] Uncaught error from Chrome WebView 143.0.7499.192 on Android 16
s6-rc: info: service legacy-services: stopping
[11:56:07] INFO: Home Assistant Core finish process exit code 0
[11:56:07] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2026-01-17 12:56:27.085 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:56:27.086 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:56:27.087 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:56:27.087 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:56:28.207 ERROR (MainThread) [homeassistant.helpers.translation] Validation of translation placeholders for localized (sv) string component.auth.mfa_setup.totp.step.init.description failed: ({'code', 'qr_code'} != {'authy_url', 'code', 'google_authenticator_url', 'qr_code'})
2026-01-17 12:56:31.840 ERROR (MainThread) [frontend.js.modern.202601072] Uncaught error from Chrome WebView 143.0.7499.34 on Android 16
[11:57:40] INFO: Home Assistant Core finish process exit code 0
[11:57:40] INFO: Home Assistant Core service shutdown
2026-01-17 12:57:49.974 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:57:49.975 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:57:49.976 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:57:49.976 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:57:51.031 ERROR (MainThread) [homeassistant.helpers.translation] Validation of translation placeholders for localized (sv) string component.auth.mfa_setup.totp.step.init.description failed: ({'code', 'qr_code'} != {'code', 'authy_url', 'qr_code', 'google_authenticator_url'})
2026-01-17 12:59:17.895 ERROR (MainThread) [frontend.js.modern.202601072] Uncaught error from Firefox 147.0 on Linux
TypeError: can't access property "querySelector", e.root.querySelector(...) is null
ha_elements (/local/custom-lovelace/compact-custom-header/custom-header.js:1:13635)
2026-01-17 12:59:18.127 ERROR (MainThread) [frontend.js.modern.202601072] Uncaught error from Firefox 147.0 on Linux
88431/</A.prototype.define (node_modules/@webcomponents/scoped-custom-element-registry/src/scoped-custom-element-registry.ts:180:12)
[11:59:37] INFO: Home Assistant Core finish process exit code 0
[11:59:37] INFO: Home Assistant Core service shutdown
2026-01-17 12:59:46.869 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:59:46.870 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:59:46.870 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:59:46.871 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-01-17 12:59:47.775 ERROR (MainThread) [homeassistant.helpers.translation] Validation of translation placeholders for localized (sv) string component.auth.mfa_setup.totp.step.init.description failed: ({'qr_code', 'code'} != {'qr_code', 'authy_url', 'google_authenticator_url', 'code'})
[core-ssh ~]$
Doesnt look to be a capacity issue.
Is the custom header on your battery lovelace dashboard card bringing things to a screaming halt? Is the device displaying it up to date, especially the browser?
Are all your other integrations including the HACS ones up to date?
Is that NVMe drive one if the ‘problem’ ones that is incompatible?
All software are up-to-date.
Don’t understand what you mean by
The error log mentions a lovelace dashboard. Is it having errors?
Some Raspberry Pi and SSDs are not compatible and have system locks. Plenty of information on the internet about it. We don’t know the model number if your drive, so we can’t search for you.
Don’t see any errors at Dashboard.
I have Samsung_SSD_960_EVO_250GB … is it compatible with Raspi5 & HA?
