schedule entity is always in âwaitingâ. i have to add something to add more debug log? i cannot see anything strange in the log. how can i check if component is up and running?
I know how to access ha logs. But there are no exception error or warning regarding schedule-component. This Is why i asked if there was possible to have more debug log or some other way to check if component Is runningâŚ
I am having trouble implementing display_option change from standard, {entity}:{action} to custom, {action} patern. I have tested a dozen of syntax variations which I encountered at this forum with no success. Below is the latest version of the code which Iâve stopped at before applying here. Whatâs wrong with that:
The items are ordered based on the time until they trigger.
You cannot define your own order.
This is also because the list is dynamic, they are discovered from your HA entities database.
I see. Thatâs also fine. I have 2 parmeters to shedule and was wondering if it is possible to have the shedules for type A placed togather and same stuff for type B so that they would not mix with eachother⌠I could have two cards for each type or keep it as it is for now, maybe it is not that confusing after allâŚ
@neliss would it be possible to only update the temperature setpoint without changing the HVAC_MODE ?
If I manually turn the thermostat off, to be kept that way when the schedule triggers?
I made a PR for extending the eQ-3 integration but I deliberately not set the HVAC_MODE together with the setpoint because I donât want the Scheduler to always turn on the thermostat.
