Schneider wiser cct5010-0003 dimmer puck2 button input?
Hello!
(ZHA whit a conbee 2 stick)
Anyone tried integrating the Schneider/wiser Dimmerpuck CCT5010-0003 (the green one) into the ZHA.
I have/had a plan to use this puck together with Home Assistant (HA) without the Wiser gateway and would like to use both control inputs on the puck to control the built in dimmer and a second light source. this would be nice for me because i have a staircase/hallway on 2 floors with 4 lights powered from 3 different breakers/phases and the puck would be an easy way to get a second control for another light.
As I understand it (according to the manual for the product) the dimmer can have two momentary switches connected where one controls the lamp connected to the dimmer iteself and the other button another function/lamp. This can be configured in the Wiser app when using the wiser hub.
But would it be possible doing that in HA somehow. I know that shelly has dim 2/ 3 that could do this but but i have a dim 2 and dont really like the dim (at least with that lamp thats connected) and i would like to run zigbee i possible.
I few questions
Anyone know if these features can be configured in HA/ ZHA?? is it possible somehowe to activate this. As it is now, atleast from what i see, i only got one input.
Does anybody have any documentation where the various zigbee clusters are described (end points, cluster and cluster attributes etc) and what possible settings these have.
Thank you
Tested this in z2m, something strange is going on this device.
It exposes group 21 and 22, where group 21 is input 1 and i assume 22 is Input2.
If you where to bind group21 to another device it works for controlling, but group 22 does not.
Sorry did not see your reply.
I can see the same thing, that it has two “groups” but in my case I can bind either 21 or 22 to a light but button/input 1 controls both of them. when looking at it in ha only button 1 have a "function.
