Scrap sensor - help
Hi all
I am trying to scrape from this site Latest Conditions in Vrilissia (meteo.gr)
this number 32.4
With webscraper tool I get the following address.
.realtime div:nth-of-type(2) .lright span
but when I am trying the below sensor in HA it doesn’t work.
- platform: scrape
    resource: https://penteli.meteo.gr/stations/vrilissia/
    select: ".realtime div:nth-of-type(2) .lright span"
    name: Vrilissia Live Temperature
    value_template: '{{value|regex_findall_index ("(\n[0-9]+)")}}'
    unit_of_measurement: '°C'
What am I missing?
Hmmm, MS Edge shows me a different selector for temperature value:
body > div.content > div.content_values > div.col.left_col > div.col_sub.dist.boxshadow.realtime > div:nth-child(2) > div.lright > span
Can you try this one?
can you please tell me what exactly I should add in the select: ?
I am not familiar with all these.
He means that the path that you are walking should be a bit different.
  - platform: scrape
    resource: http://penteli.meteo.gr/stations/vrilissia/
    select: "body div.content div.content_values div.col.left_col div.col_sub.dist.boxshadow.realtime div:nth-child(2) div.lright span"
Which shows this
note that I changed it to HTTP …with the S … I got ssl certificate errors
Thanks! it was the ssl certificate the problem.
I added in the sensor the following and it is working as admiralstipe code also
verify_ssl: false
