Scrape sensor for simple text
Hi guys. I think this is where my question should be asked, but I’m not sure. Please slap me if not.
I am using multiscrape to scrape a webpage that is made by adruino. the webpage is as follows:
23.69
37.85
967.22
789.32
143.07
Girls 2023-04-27 Giraffe CalTemp:-0.74 CalHum:0.00
Of course, the numbers change. It’s an environment sensor. Here’s my code for the sensor:
resource: http://192.168.1.31/
scan_interval: 5
unique_id: bme680_girlsroom_temperature
name: bme680 girlsroom temperature
select: “”
value_template: “{{ value }}”
I do not know what to put in select to get each number. Or the value template for that matter. Can you help?
What is the HTML source for the page? If it’s just plain text as you have posted, you should use a rest sensor rather than scraping it. Do “View Source” in your browser and paste the results as code here by surrounding with three backticks:
PASTE SOURCE HERE
If you use the RESTful integration, you can create a sensor for each number off one request:
RESTful - Home Assistant
What does each number represent?
Yup, that worked, thank you!
