When I use the Scrape Sensor, I receive the following errors in the log file for a certain instance.
2017-08-16 23:45:00 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 381, in async_process_entity
new_entity, self, update_before_add=update_before_add
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 212, in async_add_entity
yield from self.hass.async_add_job(entity.update)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/scrape.py", line 98, in update
value = raw_data.select(self._select)[0].text
IndexError: list index out of range
I have other Scrape sensors working just fine. The one that gives the issues uses the following configuration:
- platform: scrape
scan_interval: 3600
resource: "http://aqicn.org/city/belgium/fla/beveren-waas/"
select: "td#cur_pm10"
unit_of_measurement: "μg/m3"`
The strange thing is that it sometimes does seem to work, but only a very few times. I have installed beautifulsoup4==4.6.0
I tried to debug the scrape.py file with breakpoints using PyCharm, but was unsuccessful as I’m new to Python. Is there a way to debug a specific component like in my case?
Thank you in advance!
