Hey @thomasprior, I ve been using your component for a couple of days now.
It’s working great so far.
Any chance we could get the estimates for daily eth production imported?
I ve been trying to make a db sensor to give me an estimate of the eth difference (1h, 6h, 12h, 24h) but I can’t seem to be able to… (I also tried statistics sensor without luck. Next is utility meter sensor)
Also, why do you need a currency input in the config since the currency estimates are not implemented yet? I don’t get it.
I’m working on a dashboard with a lot of info, I’m currently trying to implement hive OS api statistics into it.
If it’s in the API I can try to get it added this weekend.
As for the local currency conversion, it’s something I have been planning to implement since day 1 but haven’t actually finished. The perils of adult life, eh?
I’m not comfortable creating metrics myself that would otherwise affect others interpretation of the data. That said, in the dev branch I’ve enabled the coinsPerMin attribute from the API which is described as follows:
“Estimated number of coins mined per minute (based on your average hashrate as well as the average”
Based on this data, you could extrapolate out to 1h, 6h, 12h and 24h by creating a template sensor for each, and then you can use that sensor however you’d like.
Would this get you closer to what you need?
Edit: also the currency conversion stuff is in the dev branch too! If you feel like testing it, please grab the files from the branch and let me know if you encounter any issues. Thanks for using my code!
