Scrape YAML updates
When changing Scrape yaml files, what is required to have the changes recognized. I know it creates a sensor, but there is no longer a "sensor" option for YAML reloading (I think it got incorporated into "templates"). So will reloading templates refresh scrape, or does it require a HA restart like configuration?
EDIT: I'm beginning to wonder if the Docs are correct and if the YAML support for Scrape still exists. Can anyone confirm that they still use scrape.yaml successfully today? I can't even get it to create the sensors, even if they don't render correctly. That at least happened in the Integration.
Any changes to configuration.yaml requires an HA restart. I just tested with the documentation simple example and it's working fine for me.
Thanks for this response. I finally got it to work. Not sure what I did differently.
