Hi All,
I’ve been using a web scraper to report the status of a free EV charger around the corner from my house. It’s been working rock solidly for several weeks but recently the sensor stopped loading and the following is visible in the logs:
Logger: homeassistant.components.sensor
Source: components/rest/data.py:60
Integration: Sensor (documentation, issues)
First occurred: 12:28:23 (1 occurrences)
Last logged: 12:28:23
Error while setting up scrape platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 250, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/scrape/sensor.py", line 108, in async_setup_platform
await rest.async_update()
File "/usr/src/homeassistant/homeassistant/components/rest/data.py", line 60, in async_update
response = await self._async_client.request(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1527, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1614, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1642, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1679, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1716, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 253, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 237, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 86, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 63, in handle_async_request
stream = await self._connect(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 150, in _connect
stream = await stream.start_tls(**kwargs)
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 76, in start_tls
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 67, in start_tls
ssl_stream = await anyio.streams.tls.TLSStream.wrap(
File "/usr/local/lib/python3.10/site-packages/anyio/streams/tls.py", line 122, in wrap
await wrapper._call_sslobject_method(ssl_object.do_handshake)
File "/usr/local/lib/python3.10/site-packages/anyio/streams/tls.py", line 130, in _call_sslobject_method
result = func(*args)
File "/usr/local/lib/python3.10/ssl.py", line 975, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:997)
I can see there is an SSL related error towards the end but I’m not scraping an SSL URL. Can anyone else help diagnose?
Thank you
