I have 2 windscreens at my home.
Both are powered by a Fibaro FGR223/screen
The left screen can calibrate and I can open or close it to a certain percentage. This is the desired behavior as most of the time we only close them 50% unless there are strong winds.
The right screen can’t calibrate. It just stops. The only option I seem to have there is to fill in the parameters 156 (time of up movement) and 157 (Time of down movement) and I can completely open and close it (I can’t when I calibrate, it’s only about 20cm up and down then).
However, this doesn’t allow me to open or close it to a certain percentage. I even sometimes have to close it a bit more when I want to move it up, as the up-button is greyed out because Home Assistant doesn’t know the possition.
I checked all values of the parameters, and they are the same for both.
Is there a way to overrule this in Home Assistant? That it remembers the position with the time close or open? Or are there other ways?
I already swapped out the Fibaro module, but it’s the same behavior for both.
The only difference between the 2 is the lenght of the cable to the screen, but since I can fully close and open the screen this doesn’t seem to be an issue (if you don’t count callibration).
