Script entity name doesn't match
Hi there,
I feel like I may have found an issue.
I used to have a script named ‘script.clean_the_litterbox’. Some time ago we moved to a new place, this got broken in the process, and I deleted it and replaced it with a new script. I initially wanted to name it the same, but that failed, so I changed the name.
Now, according to the settings of the script, it looks like this:
However, I can’t add ‘script.vacuum_near_litterbox’ to buttons in my dashboards. When searching for the name, it lists the name as ‘script.clean_the_litterbox_2’. I’ve tried changing the entity name multiple times now, but whatever I do, the UI/Lovelace will ONLY recognize it as ‘script.clean_the_litterbox_2’.
Does anyone know how I can fix this?
Thanks!
