Script fail log
Im trying to get a script working but gets this fail no matter what i do?:
2018-01-17 16:04:53 ERROR (Thread-2) [homeassistant.util.yaml] Unable to read file /home/homeassistant/.homeassistant/scripts.yaml: ‘utf-8’ codec can’t decode byte 0xe5 in position 42: invalid continuation byte
2018-01-17 16:04:53 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: ‘utf-8’ codec can’t decode byte 0xe5 in position 42: invalid continuation byte
you might have a unicode å in your file.
netradio:
alias: Afspil Radio på Chromecast Audio
sequence:
- service: media_player.volume_set
entity_id: media_player.kkken__stue
volume_level: ‘0.30’
entity_id: media_player.badevrelse
volume_level: ‘0.20’
entity_id: media_player.garage_speaker
- service: media_player.play_media
entity_id: >
{% if is_state(“input_select.chromecast_radio”, “Køkken/stue”) %} media_player.kkken_stue
{% elif is_state(“input_select.chromecast_radio”, “Badeværelse”) %} media_player.badevrelse
{% elif is_state(“input_select.chromecast_radio”, “Garage”) %} media_player.garage_speaker
{% elif is_state(“input_select.chromecast_radio”, “Alle rum”) %} media_player.home_group
{% endif %}
media_content_id: >
{% if is_state(“input_select.radio_station”, “Det rigtige Faaborg”) %} http://stream.wlmm.dk/detrigtigefaaborg
{% elif is_state(“input_select.radio_station”, “myROCK”) %} http://tx-bauerdk.sharp-stream.com/http_live.php?i=myrock_dk_tunein_mp3
{% elif is_state(“input_select.radio_station”, “P3”) %} http://live-icy.gss.dr.dk/A/A05H.mp3
{% endif %}
media_content_type: ‘audio/mp4’
scripts.yaml (1.5 KB)
It doesn’t like your alias :
because of the unicode character å
Try changing it to
alias: Afspil Radio pa Chromecast Audio
thanks. Now there is some other problem:
2018-01-17 17:32:50 ERROR (Thread-2) [homeassistant.util.yaml] Unable to read file /home/homeassistant/.homeassistant/scripts.yaml: ‘utf-8’ codec can’t decode byte 0xf8 in position 665: invalid start byte
2018-01-17 17:32:50 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: ‘utf-8’ codec can’t decode byte 0xf8 in position 665: invalid start byte
You need to take all the non-ascii characters out of your script.
I can see ø, and æ,
These have to go.
But it has been working with my old installation. Will try to update my hassbian first off
What editor are you using. Be sure you are saving your files with an editor that supports UTF8 encoding.
does notepad++ support that?
