Hi, I have simple automation that triggers my Nest to a certain temp for an hour when my daughters room is under 18 degrees. Was working last week, dont know why its started failing now. The script fails without automation triggered or forced.
My script:
‘1548859227197’:
alias: ‘Nest: 1 Hour Boost test’
sequence:
- data:
temperature: ‘22’
service: climate.set_temperature - delay: 01:00:00
- data:
temperature: ‘16’
Automation:
- id: ‘1573080097272’
alias: XXs Room Trigger
description: Trigger 1hr heating if temp below 18
trigger:- below: ‘18’
entity_id: sensor.temperature_158d000224cd36
platform: numeric_state
condition: []
action: - service: script.1548859227197
- below: ‘18’
Log entry
2019-11-13 12:53:58 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1824194960] ‘NoneType’ object has no attribute ‘is_on’
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 133, in handle_call_service
connection.context(msg),
File “/usr/src/homeassistant/homeassistant/core.py”, line 1233, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File “/usr/src/homeassistant/homeassistant/core.py”, line 1258, in _execute_service
await handler.func(service_call)
File “/usr/src/homeassistant/homeassistant/components/script/init.py”, line 139, in service_handler
if script.is_on:
AttributeError: ‘NoneType’ object has no attribute ‘is_on’
On latest Hass version. Any help appreciated
