firstly i want to mention that i am knew with writing scripts and also a bit confused. Secondly, my overall goal is to change source on TV based on which one is turned on. Once the scripts are done then i will use IFTTT to execute them via voice commands. What the script i want to do
I have 2 TVs one in the bedroom and one in the living room and instead of having one command for every app and every TV i want to choose the TV based on its state. If both are turned off i want to turn on the one in the living room and then go to the app i want. The part to choose TV when one of them is open it’s ok. I m having a problem with the script that turns on the tv.
I was thinking of checking if both TVs are off, then turn one ON and then continue to the code that i have already and working that chooses between the 2 TVs. If anyone has an idea of how to do it or a better way to do it i would be grateful. The code i have and working is at the end…
netflix:
alias: Netflix Script
sequence:
- service: media_player.select_source
data_template:
entity_id: >
{% if (states('media_player.bedroom_tv') == 'on') %}
{%-elif (states('media_player.living_room_tv') == 'on') %}
{% else %}
### MAYBE I WILL USE THIS PART TO TURN ON THE TV ###
{% endif %}
source: 'Netflix'
