I was coding a generic script for turn off some lights, simple script like this:
timer_off_luces:
alias: "Apaga las luces automaticamente cuando no hay movimiento"
mode: restart
fields:
group_motion:
description: "Grupo de sensores de movimiento"
example: motion_sensors_plantabaja
switch:
description: "Switch a apagar"
example: pasillo_switch
timeout:
description: "Timeout para apagar en caso de que no se apague automaticamente"
example: "00:03:00"
variables:
group_motion_c: "{{ 'group.{}'.format(group_motion) }}"
switch_c: "{{ 'switch.{}'.format(switch) }}"
sequence:
- wait_for_trigger:
platform: template
value_template: "{{ is_state(group_motion_c, 'off') }}"
timeout: "{{ timeout }}"
continue_on_timeout: true
- service: homeassistant.turn_off
data_template:
entity_id: "{{ switch_c }}"
I’m using mode=restart because I want to restart the script (for reset the timeout) but I’m running multiple instances at the same time for this script using differences parameters (for different entities) … and I’m not sure what will do HA when is running the script in “restart” mode and with different parameters.
Thanks!
