Script syntax help please
I have the below script to turn one light off and three others on to different colours but when config checking it results in errors.
I’m not sure what I’ve done wrong or what to do to correct it. Can someone please advise?
sunset_master_bedroom:
  alias: Sunset Master Bedroom
  icon: "mdi:weather-sunset-down"
  sequence:
    - service: light.turn_on
        - entity_id: light.headboard
          brightness: 80
          rgb_color:
          - 131
          - 50
          - 168
          transition: 120
        - entity_id: light.m_bedside
          brightness: 80
          rgb_color:
          - 219
          - 57
          - 63
          transition: 120
        - entity_id: light.r_bedside
          brightness: 80
          rgb_color:
          - 209
          - 96
          - 158
          transition: 120
    - service: light.turn_off
        entity_id: light.bedroom_light
Try this instead… :slight_smile:
  sequence:
        brightness: 80
        rgb_color:
          - 131
          - 50
          - 168
        transition: 120
        brightness: 80
        rgb_color:
          - 219
          - 57
          - 63
        transition: 120
        brightness: 80
        rgb_color:
          - 209
          - 96
          - 158
        transition: 120
The elements within the data: block are not a list -, but a dictionary of key: value.
Also, entity_id is one of those “special” keys that can be defined outside the data: block even if you have a data: block.
That sorted it.
Thanks for your help, Tony, it’s much appreciated.
Unfortunately, this is a bit inconsistent. See this issue:
Fair point, I forgot about that pain… :frowning:
I have avoided it for the most part or had a WTH moment when it happens…
Thanks, I’ll bear that in mind but, in this case, the code works for my Hue lights.
It’s confusing and I wasn’t aware of this conflict but I’ll try and remember to move the entity_id if I encounter future issues and see how it goes.
