Script Template condition not working
Hi all,
I just don’t get the following script to work:
if:
  - condition: template
    value_template: |-
      "{{ (states('input_number.poolpump_running_time_today') | int) <
        (states('input_number.poolpump_running_time_threshold') | int) }}"
    then:
The condition is always returning false, however the template returns true as expected when using the template debugger in the developer tools.
Just a guess, but does it have to be:
    value_template: >
or just in a single line:
    value_template: "{{ (states('input_number.poolpump_running_time_today') | int) < (states('input_number.poolpump_running_time_threshold') | int) }}"
Thanks! I don‘t fully understand it, but it works when just using a single line.
On a single line you have to use quotes. With the multiline options you should omit the wrapping quotes, so the multiline solution should be:
    value_template: >
To understand the various multiline options better, look here: https://yaml-multiline.info/.
