Script Templating Help - If-else for Spotify source
I’ve got an Amazon Echo that I want to play music on using the Spotify integration. Everything works fine except for sometimes the source name will change from ‘Living Room’ to ‘Echo-576’. Somehow the echo is loosing it’s name and is switching back and forth between it’s default name and the one I assigned.
So I thought I could use an if-else template to dynamically change the source name depending on if ‘Living Room’ is defined in the Spotify source list.
Here’s what I have:
yoga_time_music_play:
  alias: Play Yoga Playlist on Living Room Echo
  sequence:
    - service: media_player.select_source
        entity_id: media_player.spotify_clint_williams
        source: >
          {% if 'Living Room' in state_attr("media_player.spotify_clint_williams", "source_list") %}
            Living Room
          {% else %}
            Echo-576 Speaker
          {% endif %}
    - service: media_player.volume_set
        volume_level: 0.4
    - service: media_player.play_media
        media_content_type: playlist
        media_content_id: spotify:playlist:0tZKB07WrNju5Ac2hvhPyV
It sets the volume and plays the content but not on the source specified.
If I delete the template and just use ‘source: Echo-576 Speaker’ everything works fine.
I’ve tried all kinds of variations on the formatting and it just won’t work. Can anyone please help?
P.S. There used to be an alias optional configuration for the Spotify integration where you could define an alias for each of your sources device id’s. What happened to that?
data_template: for the first service. Because you are using… a template.
Wow. Thanks so much. I really thought I had tried everything :man_facepalming:
