Copy-Bulb
Home Assistant script to copy one bulb to another with random colour and brightness variations.
I wrote this because we have a couple of places that I wanted one or two particular light bulbs to be set to a different (but pleasant) contrast to the other bulbs in the room.
We have two outside lights on a porch, and a third light above the house number plate - no matter what colours and settings the two porch lights are at I wanted the plate light to be a contrast to them.
In another use case there is a room with four ceiling lights and a table lamp, I wanted the table lamp to be the same colour as the ceiling lights but always a slightly brighter and richer colour.
Rather than implementing this as an automation, I’ve done it as a script that can then be used multiple times by several automations in different situations.
Install
Script is here, just copy and past it into the script editor in yaml mode:
alias: Copy Bulb
description: Copy one bulb to another with random variations.
fields:
description: Bulb settings to copy from.
selector:
entity:
filter:
- domain: light
example: light.pg1
required: true
to:
description: Bulb settings to copy to.
selector:
entity:
filter:
- domain: light
example: light.psr1
required: true
hue_mode:
name: (OPTIONAL) Hue Mode
description: Method to vary hue. Defaults to none.
selector:
select:
options:
- none
- complementary
- analogous
- close
- subtle
- triadic
- tetradic
- random
example: complementary
required: false
sat_mode:
name: (OPTIONAL) Saturation Mode
description: Method to vary saturation. Defaults to none.
selector:
select:
options:
- none
- desaturate
- resaturate
- random
example: desaturate
required: false
saturation_range_low:
name: (OPTIONAL) Saturation Range Low
description: >-
When varying saturation, vary by at least this much or if random at least
this. Defaults to 30%.
selector:
number:
min: 0
max: 100
unit_of_measurement: "%"
example: 25
required: false
saturation_range_high:
name: (OPTIONAL) Saturation Range High
description: >-
When varying saturation, vary by at most this much or if random at most
this. Defaults to 80%.
selector:
number:
min: 0
max: 100
example: 25
required: false
brightness_mode:
name: (OPTIONAL) Brightness Mode
description: >-
Method to vary brightness by. Defaults to none but if varied will make
sure brightness is > 20%.
selector:
select:
options:
- none
- brighter
- dimmer
- random
example: dimmer
required: false
brightness_range_low:
name: (OPTIONAL) Brightness Range Low
description: >-
When varying brightness, vary by at least this much or if random always
above this. Defaults to 30%.
selector:
number:
min: 0
max: 100
example: 25
required: false
brightness_range_high:
name: (OPTIONAL) Brightness Range High
description: >-
When varying brightness, vary by at most this much or if random always
below this. Defaults to 80%.
selector:
number:
min: 0
max: 100
example: 25
required: false
transition:
description: How long in seconds to transition the copy. Defaults to 0 seconds.
selector:
number:
min: 0
max: 100
step: 0.1
unit_of_measurement: sec
example: 3
required: false
sequence:
- if:
- condition: template
value_template: "{{ states(from) == 'off' }}"
then:
- data: {}
entity_id: "{{ to }}"
action: light.turn_off
else:
- variables:
src_hs: "{{ state_attr(from, 'hs_color') }}"
src_br: "{{ state_attr(from, 'brightness') }}"
h_mode: "{{ hue_mode if hue_mode is defined else \"none\" }}"
s_mode: "{{ sat_mode if sat_mode is defined else \"none\" }}"
b_mode: "{{ brightness_mode if brightness_mode is defined else \"none\" }}"
srl: >-
{{ saturation_range_low if saturation_range_low is defined else "30"
srh: >-
{{ saturation_range_high if saturation_range_high is defined else
"80" }}
brl: >-
{{ brightness_range_low if brightness_range_low is defined else "30"
brh: >-
{{ brightness_range_high if brightness_range_high is defined else
"80" }}
dst_br: |-
{%- macro b_random_dimmer(b,l,h) -%}
{{- [50, (b * (1 - ((range(l,h) | random) / 100)))] | max | round(3) | float -}}
{%- endmacro -%}
{%- macro b_random_brighter(b,l,h) -%}
{{- [255, (b + ((255 - b) * ((range(l,h) | random) / 100)))] | min | round(3) | float -}}
{%- endmacro -%}
{%- macro b_random(l, h) -%}
{{- [255, [50, (range(l,h) | random) * 2.55] | max] | min | round(3) | float -}}
{%- endmacro -%}
{%- if b_mode == "none" -%}
{{- src_br -}}
{%- elif b_mode == "brighter" -%}
{{- b_random_brighter(src_br, brl, brh) -}}
{%- elif b_mode == "dimmer" -%}
{{- b_random_dimmer(src_br, brl, brh) -}}
{%- elif b_mode == "random" -%}
{{- b_random(brl, brh) -}}
{%- else -%}
{{- src_br -}}
{%- endif -%}
dst_h: |-
{%- macro h_complementary(c) -%}
{{- ((c + 180) % 360) | round(3) -}}
{%- endmacro -%}
{%- macro h_random_analogous(c) -%}
{{- ((c + ([-30, 30] | random)) % 360) | round(3) -}}
{%- endmacro -%}
{%- macro h_random_analogous_close(c) -%}
{{- ((c + ([-15, 15] | random)) % 360) | round(3) -}}
{%- endmacro -%}
{%- macro h_random_analogous_subtle(c) -%}
{{- ((c + ([-7.5, 7.5] | random)) % 360) | round(3) -}}
{%- endmacro -%}
{%- macro h_random_triadic(c) -%}
{{- ((c + 120 * ([1, 2] | random)) % 360) | round(3) -}}
{%- endmacro -%}
{%- macro h_random_tetradic(c) -%}
{{- ((c + 90 * ([1, 2, 3] | random)) % 360) | round(3) -}}
{%- endmacro -%}
{%- macro h_random() -%}
{{- (range(0, 360) | random) | round(3) -}}
{%- endmacro -%}
{%- if h_mode == "none" -%}
{{- src_hs[0] -}}
{%- elif h_mode == "complementary" -%}
{{- h_complementary(src_hs[0])|float -}}
{%- elif h_mode == "analogous" -%}
{{- h_random_analogous(src_hs[0])|float -}}
{%- elif h_mode == "close" -%}
{{- h_random_analogous_close(src_hs[0])|float -}}
{%- elif h_mode == "subtle" -%}
{{- h_random_analogous_subtle(src_hs[0])|float -}}
{%- elif h_mode == "triadic" -%}
{{- h_random_triadic(src_hs[0])|float -}}
{%- elif h_mode == "tetradic" -%}
{{- h_random_tetradic(src_hs[0])|float -}}
{%- elif h_mode == "random" -%}
{{- h_random()|float -}}
{%- else -%}
{{- src_hs[0] -}}
{%- endif -%}
dst_s: |-
{%- macro s_random_desat(c,l,h) -%}
{{- [0, (c * (1 - ((range(l,h) | random) / 100)))] | max | round(3) | float -}}
{%- endmacro -%}
{%- macro s_random_resat(c,l,h) -%}
{{- [100, (c + ((100 - c) * ((range(l,h) | random) / 100)))] | min | round(3) | float -}}
{%- endmacro -%}
{%- macro s_random(l,h) -%}
{{- [100, [0, (range(l,h) | random)] | max] | min | round(3) | float -}}
{%- endmacro -%}
{%- if s_mode == "none" -%}
{{- src_hs[1] -}}
{%- elif s_mode == "resaturate" -%}
{{- s_random_resat(src_hs[1],srl,srh)|float -}}
{%- elif s_mode == "desaturate" -%}
{{- s_random_desat(src_hs[1],srl,srh)|float -}}
{%- elif s_mode == "random" -%}
{{- s_random(srl,srh)|float -}}
{%- else -%}
{{- src_hs[1] -}}
{%- endif -%}
- data: >-
{ {%- if transition is defined -%} "transition" : {{ transition }},
{%- endif -%} "hs_color" : ({{ dst_h }}, {{ dst_s }}), "brightness" :
{{ dst_br }} }
action: light.turn_on
mode: parallel
icon: mdi:lightbulb-multiple
max: 30
max_exceeded: silent
Examples
Here is an automation that uses the script to copy the colour of one of the porch bulbs to the bulb above the house number plate, using a tetradic colour, making it slightly brighter and less saturated:
alias: House Number Light Controller
description: Change the colour of the house number light on to stand out.
triggers:
- entity_id:
- light.porch_light_1
attribute: hs_color
for:
hours: 0
minutes: 0
seconds: 30
trigger: state
- entity_id:
to: "off"
trigger: state
- entity_id:
to: "on"
trigger: state
conditions: []
actions:
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- if:
- condition: trigger
id:
- "Off"
then:
- action: homeassistant.turn_off
metadata: {}
data: {}
entity_id: light.house_number
else:
- data:
to: light.house_number
hue_mode: tetradic
brightness_mode: brighter
sat_mode: desaturate
action: script.copy_bulb
mode: restart
Stuck this on Github just in case it ever updates: Github: Copy-Bulb
