Here is the file of my script - I’d love you to try to help me align the file to your code.
https://paste.ofcode.org/zD2vyFfpQZksei74twkM3W
You don’t put the code in the scripts.yaml file. It’s not a yaml code, it’s a python script.
create a folder named python_scripts in your home assistant configuration directory (in the same directory where your configuration.yaml is located - on my Raspberry Pi install it is located at /home/homeassistant/.homeassistant)
in that folder create a file called populate_catchall_group.py
copy the code from the first block at the beginning of this thread into that file and then save it.
in your groups configuration create a group called “catchall” from the example posted by NigeIL in post #5 above.
in your configuration.yaml file add the line python_script: somewhere.
save everything
restart home assistant
now in the developers tools section of the home assistant interface go to the services icon. there you will find a drop down menu. locate the entry “python_script.populate_catchall_group”, select it then click on the “call service” button.
done. - hopefully…
yay!
Hi @finity
if you change the line
hass.states.set("group.catchall", catchall.state, attrs)
to
if len(entity_ids) > 1:
that should do it.
(the If should be at the same indent level as the current hass.states line, and hass.states should be one level further indented)
Thanks, I’ll give it a try.
And no problem!
I’m going to try this out and just wanted to make sure the script was correct with changes mentioned throughout:
ignore = data.get("domains_to_ignore","zone,group,automation,script,zwave")
domains_to_ignore=ignore.split(",")
target_group=data.get("target_group","group.catchall")
logger.info("ignoring {} domain(s)".format(len(domains_to_ignore)))
logger.info("Targetting group {}".format(target_group))
def scan_for_new_entities(hass, logger, domains_to_ignore, target_group):
entity_ids=[]
groups=[]
catchall=hass.states.get(target_group)
if (catchall is None):
attribs={"view":True, "friendly_name": "Ungrouped Items", "icon": "mdi:magnify"}
hass.states.set(target_group, "", attribs)
for state in hass.states.all():
domain = state.entity_id.split(".")[0]
if (domain not in domains_to_ignore):
entity_ids.append(state.entity_id)
if (domain == "group") and (state.entity_id != target_group):
groups.append(state.entity_id)
logger.info("==== Entity count ====")
logger.info("{0} entities".format(len(entity_ids)))
logger.info("{0} groups".format(len(groups)))
for groupname in groups:
group = hass.states.get(groupname)
for a in group.attributes["entity_id"]:
if a in entity_ids:
entity_ids.remove(a)
attrs={}
for a in catchall.attributes:
if a != "entity_id":
attrs[a] = catchall.attributes[a]
entity_ids.insert(0,"script.scan_for_new_devices")
attrs["entity_id"]=entity_ids
I don’t have my system in front of me right now to test it, but that looks like it should work.
Yes, it works great, Thanks.
I see you included the line (from post #24) to prevent the catchall group from showing up if it is empty. Does it still show the catchall group even if it’s empty?
@NigelL
I can’t get that part to work correctly. mine still shows up even tho it’s empty.
HI, thanks for this!
works really fine, and ive rediscovered several items lost
when including groups, the script detects all groups that have view: true
as being ungrouped… Is there a way to adapt the script to include groups, but leave the views, tabs, out?
also, as a solution for displaying it without the need to put the group in a yaml group anywhere, maybe this could be included:
- service: group.set
object_id: catchall
view: true
visible: true
that way it would show up as a tab in the main frontend showing all entries automatically?
like: attribs={"visible":true, "view":True, "friendly_name": "Ungrouped Items", "icon": "mdi:magnify"}
Hi @finity, If you have the indentation levels right, it will not add the group unless there are two or more items in it (including the trigger for the script). However, there is currently nothing in the script to remove the group if it already exists.
If you have already dealt with everything in the view, and want to get rid of it, you might need to restart HA.
Love this, will hopefully integrate it so that the view appears when my maintenance mode is on, and disappears when it’s off.
Thanks for sharing
Hi @Mariusthvdb
in order to get groups that aren’t included anywhere, try this (I’m not actually on my HA system right now, but this should work, or at least be pretty close). I can verify it when I am done work if necessary.
Remove group from the domains_to_ignore variable or parameter
Change the block which is currently this
to
if (domain == "group"):
if (state.entity_id != target_group):
if (("view" in state.entity_id.attributes) and (state.entity_id.attributes["view"] == false)):
I will take a look at the group.set service (I wasn’t aware of it until just now, and also see there’s a group.remove). One thing I have found frustrating is because I am doing everything inside a function, a lot of objects aren’t automatically available (which is why I pass hass and logger into the function)
cool.
we can set the groups visibility and the view easily with the code I posted.
Ive filed a request to do so with a template, as is possible with group.set_visibility alone.
which is kind of cool, since one can then template that depending on a mode (in my settings a dev-mode… or not)
as it stands now, we have to hard code it. Works but less elegant.
Running the python script now creates the group as a view, as I have screenshot and posted.
We should be able to toggle the view. Instead of always setting to true, we should be able to enable/disable when we want it
Ohh…that is unfortunate. I guess, we can have two separate actions
yes, that how I do it now:
scene_normal:
alias: Call Normal scene
sequence:
- service: homeassistant.turn_off
entity_id: group.philips_motion_sensor_switches
- service: input_select.select_option
entity_id: input_select.theme
option: 'teal'
object_id: developer
view: false
visible: false
scene_developer:
alias: Call Developer scene
sequence:
option: 'matrix'
view: true
visible: true
