@samuel81 (I replied to myself apparently)
Please try test v2.2.2.2 or even test v2.2.2.3
edit: hold on
Ah right, missed something there
This one should do the trick. Version number is 2.2.2 again as I thought it was ready to merge.
Iâm sorry, I need to revise what I wrote before:
Tested both, test v2.2.2.2 works, test v2.2.2.3 doesnât turn up the volume. Both traces are here:
V2.2.2.2:
- Works with scenario 1 (volume up, resume, volume correct after resume) (CodePile | Easily Share Piles of Code)
- Doesnât work with scenario 2 - (no volume up, no resume) (CodePile | Easily Share Piles of Code)
V2.2.2.3:
- Doesnât work with scenario 1 - (volume not correct, but resume (CodePile | Easily Share Piles of Code)
- Doesnât work with scenario 2 - (volume not correct, no resume) ( CodePile | Easily Share Piles of Code | Pile)
V2.2.2:
- Doesnât work with scenario 1 (volume not correct, but resume) (CodePile | Easily Share Piles of Code)
- Doesnât work with scenario 2 (volume not correct, no resume) (CodePile | Easily Share Piles of Code)
Scenarioâs:
Scenario 1:
alias: 'Test: Spotify Resume with TTS Script'
description: Test automation for Spotify Resume, using script by TheFes
- platform: state
entity_id: input_select.matthijs_status_dropdown
to: Extended Away
condition: []
- service: script.turn_on
entity_id: script.google_home_resume
variables:
- service: script.test_for_tts
entity_id: media_player.all_speakers
entity: media_player.all_speakers
extra:
volume: 0.5
mode: single
Scenario 2 ( script.turn_on
with variables
under data
alias: 'Test2: Spotify Resume with TTS Script (Duplicate)'
- platform: state
to: Extended Away
condition: []
variables:
entity_id: script.test_for_tts
variables:
extra:
volume: 0.4
mode: single
Tested with:
- On some players there is music playing.
- On no players there is music playing.
- Music was played with Spotify.
You are right, I got confused myself.
Setting the volume with scenario 2 will not work, it will only work with scenario 1.
The separate target is only used for resume, not for the volume_set action.
I will have to clear that up in the docs.
So, please use scenario 1. I will look into why the volume isnât working though.
micro version numbers are back test 2.2.2.5 is ready for testing.
Volume setting and resume should work with scenario 1, thinking of adding an option to add targets to extra
to make scenario 2 work
Just uploaded v2.2.2.6
That should also allow scenario 2 if you use it it like this:
- platform: state
to: Extended Away
condition: []
variables:
variables:
extra:
volume: 0.4
mode: single
Unfortunately not with Scenario 2, but still works with Scenario 1âŚ
Trace for Scenario 2: CodePile | Easily Share Piles of Code
Okay, I will dig into that, seems to be another issue.
Thanks for testing
Found it With the new v2.2.2 v2.3.0 you should be able to use the script like I suggested.
#Update
Version 2.3.0 / 2.3.1 - 14 April 2022
New features
- Targets (
entity_id
,device_id
and/orarea_id
) can be added toextra
orscript_extra
sovolume
can be applied to those entities for a specific service call in which they are not mentioned as targets themselves (eg when calling a script)
Improvements
- Moved the volume change before the service call
- As volume changes to a Google Home speaker group are no longer synced to their members (due to patent reasons) the volume set in the
extra
orscript_extra
setting will be sent to the members of the speaker group. - Targets entered in
extra
orscript_extra
will also be taken into account for resuming afterwards
Bug fixes
- Removed a bug where group members of a speaker group were added to the players to be resumed, while they were not playing
- (2.3.1) Fix for targets provided under
extra
Hmm⌠some errors after upgrade:
Google Home Resume script track: CodePile | Easily Share Piles of Code
Error doing job: Task exception was never retrieved
5:18:24 PM â (ERROR) helpers/condition.py
00 đ Google Home Resume - Restore non playing: Error executing script. Error for wait_template at pos 1: In 'template' condition: TemplateError: str: Invalid domain name ''
5:18:24 PM â (ERROR) Script
[([::ffff:c0a8:116]):8009] Failed to connect to service ServiceInfo(type='host', data=('[::ffff:c0a8:116]', 8009)), retrying in 5.0s
5:16:15 PM â (ERROR) /usr/local/lib/python3.9/site-packages/pychromecast/socket_client.py - message first occurred at 5:16:15 PM and shows up 2 times
The error seems to be in the script to restore the non playing entities, could you send the trace of that script?
Oh wait, skip that, itâs not in that script. Let me investigate this a bit further
Could you give 2.3.2 a try?
For what I can see one of your speakers was unavailable. This caused that an incorrect value was stored in the player data, which then caused that the whole player data list was stored as a string.
And this then caused that incorrect data was sent to the script to restore the non playing entity.
Logger: homeassistant.components.script.google_home_resume
Source: helpers/script.py:1397
Integration: Script ([documentation](https://www.home-assistant.io/integrations/script), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+script%22))
First occurred: 8:40:59 AM (1 occurrences)
Last logged: 8:40:59 AM
00 đ Google Home Resume: Error executing script. Error rendering template for variables at pos 9: TemplateRuntimeError: No test named 'off'.
Sorry about that, should be fixed in 2.3.3
Different error:
Logger: pychromecast.socket_client
Source: /usr/local/lib/python3.9/site-packages/pychromecast/socket_client.py:396
First occurred: 10:16:28 AM (2 occurrences)
Last logged: 10:16:28 AM
[([::ffff:c0a8:116]):32001] Failed to connect to service ServiceInfo(type='host', data=('[::ffff:c0a8:116]', 32001)), retrying in 5.0s
And if tried youtube music interrupted by TTS (not working):
Source: helpers/template.py:409
First occurred: 10:20:32 AM (2 occurrences)
Last logged: 10:22:03 AM
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 407, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1820, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 1291, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 926, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 8, in top-level template code
jinja2.exceptions.UndefinedError: 'time' is undefined
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 412, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1275, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 359, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 379, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 832, in _async_variables_step
self._variables = self._action[CONF_VARIABLES].async_render(
File "/usr/src/homeassistant/homeassistant/helpers/script_variables.py", line 62, in async_render
rendered_variables[key] = template.render_complex(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 132, in render_complex
return value.async_render(variables, limited=limited, parse_result=parse_result)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 409, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'time' is undefined
I donât think the PyChromecast error is something I can fix.
The other error Iâm not sure, could you send me the trace?
