Script variable creation syntax
Writing a simple script that would concatenate which bins are to be collected, and tts_say’ing the response to Google Assistant:
bin_fairy_which_bins:
  alias: "Which bins will be collected"
  icon: mdi:delete-empty
  mode: single
  sequence:
    - variables:
        message: >
          {%- set messageToSay = "The following bins will be collected: ") %}
          {%- if states('sensor.sua_bincollection_next_includes_recycling') == 'true' %}
            {%- set messageToSay = messageToSay + "Recycling, " %}
          {%- endif %}
          {%- if states('sensor.sua_bincollection_next_includes_garden_waste') == 'true' %}
            {%- set messageToSay = messageToSay + "Garden Waste, " %}
          {%- endif %}
          {%- if states('sensor.sua_bincollection_next_includes_general_refuse') == 'true' %}
            {%- set messageToSay = messageToSay + "General Refuse, " %}
          {%- endif %}
          {%- set messageToSay = messageToSay + "and Food waste." %}
          {{ messageToSay }}
    - alias: "TTS for speaker voice command"
      service: script.google_home_voice
        use_resume: true
          - alias: "Send TTS message"
            service: tts.google_cloud_say
              message: "{{ message }}"
        volume: 35
When loading the script, the following error shows in the logs:
Invalid config for [script]: invalid template (TemplateSyntaxError: unexpected ')') for dictionary value @ data['sequence'][0]['variables']['message']. Got None. (See /config/configuration.yaml, line 11).
Injecting a manual string on the line where I return {{ messageToSay}} makes the script load successfully, so I’m assuming {{ messageToSay }} is “null” at this point? The 4 sensors (sensor.sua_bincollection_next_includes_*) are just true/false values, so I’ve tried:
without apostrophes:
{%- if states('sensor.sua_bincollection_next_includes_recycling') == true %}
with single = :
{%- if states('sensor.sua_bincollection_next_includes_recycling') = 'true' %}
(but thinking about it now, that probably doesn’t matter since at the very end I set a value for messageToSay, (i.e. “and Food waste.”) regardless of some condition, so I would expect it to have a value.
Am I returning {{ messageToSay }} incorrectly?
Remove the ) from this line:
                                                          Remove this
