Hi all,
At the moment I have for each and every notification a script, for example;
action: notify.pushover_alarm
title: HA Alarm System -
priority: 0
sound: vibrate
ttl: 600
message: Alarm deactivated
I want to reduce the number of similar scripts, using fields.
So I created this script.
sequence:
- action: notify.pushover_alarm
title:
"[object Object]": null
priority:
sound:
ttl:
message:
alias: Alarm Pushover notification - Alarm **template**
description: ""
fields:
title:
selector:
text: null
required: true
description: your title
priority:
selector:
number:
min: -1
max: 2
step: 1
required: true
description: prio
sound:
selector:
text:
multiple: false
multiline: false
ttl:
selector:
number:
min: 1
max: 100
required: true
message:
selector:
text: null
required: true```
If I go to the developer tool / actions
And I put some test data in and view the output in YAML, I see this;
action: script.alarm_pushover_notification_alarm_template
title: test
priority: 1
sound: echo
ttl: 100
message: test
so basically the indentations and 2x data are gone. See how it was/works w/o fields at start of this topic. If I try to run it, I get this error.
Failed to perform the action script.alarm_pushover_notification_alarm_template. value should be a string for dictionary value @ data['message']. Got None value should be a string for dictionary value @ data['title']. Got None
How can I fix this?
Thanks for tips!
Regards
Jules
