Script with 'repeat while' won't pass data from automation
using a ‘repeat while’ causes me headaches, please help me out, what am I doing wrong?
this works perfectly:
  intercom_alarm:
    alias: Intercom alarm
    mode: queued
    sequence:
      - service: media_player.volume_set
          entity_id: &alarm_players
            - media_player.googlehome_hub
            - media_player.googlehome_hall
            - media_player.googlehome_master_bedroom
          volume_level: 0.6
#      - alias: repeat while alarm is armed
#        repeat:
#          while: >
#            {{states('alarm_control_panel.ha_rpi4_alarm') in ['armed_away','armed_home']}}
#          sequence:
      - service: tts.google_say #tts.cloud_say
          language: >
            {{states('input_select.intercom_language')|lower}}
          entity_id: *alarm_players
          message: >
            {% set language = states('input_select.intercom_language') %}
            {% if language == 'En' %} {{message_en}}
            {% elif language == 'Nl' %} {{message_nl}}
            {% else %} {{message_en}}
            {% endif %}
          volume_level: 0.3
but when I uncomment the repeat, nothing is played at all. What did I miss in the syntax/logic? There is no error in the log at all, and config checks fine.
  intercom_alarm:
    mode: queued
    sequence:
          volume_level: 0.6
        repeat:
          while: >
          sequence:
                language: >
                message: >
                  {% endif %}
            - delay:
                seconds: 10
          volume_level: 0.3
this is the service in the automation calling the script:
      - service: script.intercom_alarm
          message_nl: >
            {% set room = trigger.to_state.object_id.split('_sensor_motion')[0].replace('_',' ')|capitalize %}
            Alarm, {{room}} heeft beweging gesignaleerd,
              controleer wat er aan de hand is!
          message_en: >
            Alarm, {{room}} triggered the alarm, check whats up!
which as said, works as expected. So must be the script.
update
using a repeat-until syntax does work fine:
  intercom_alarm:
    mode: queued
    sequence:
          volume_level: 0.6
      - alias: repeat until alarm is disarmed
        repeat:
          sequence:
                language: >
                message: >
                  {% endif %}
            - delay:
                seconds: 10
          until: >
            {{is_state('alarm_control_panel.ha_rpi4_alarm','disarmed')}}
          volume_level: 0.3
cant find the issue with the ‘while’ loop though… for a minute I thought the a delay would be causing trouble, but after I’ve added that (edited the post in the example above with that) doesn’t make a difference.
please have a look? Thanks!
