Hi everybody.
Concerning Scripts:
In a Action is there a way to generate the service to be called using a template, and test the service generated in the data template in order to apply logic the the entity_id tp be gnerated?
i.e.:
an Action like this:
alias: 'Lights: Simulation Script'
- service: >
{% set operation = ['homeassistant.turn_on', 'homeassistant.turn_off' ] | random %}
{{ operation }}
entity_id: >
{% if operation == 'homeassistant.turn_on' %}
{{ expand('group.lights_simulation') | selectattr('state', 'eq', 'off') | map(attribute='entity_id') | list | random }}
{% elif operation == 'homeassistant.turn_off' %}
{{ expand('group.lights_simulation') | selectattr('state', 'eq', 'on') | map(attribute='entity_id') | list | random }}
{% else %}
should never use this...
{% endif %}
it seems that in data template the variable ‘operation’ in not accesible, making the script choose the final else clause.
Really thank you, really kind @123
Just another issue… in case the script should be a repeat sequence unitl …, how to make the ‘operation’ variable be regenerated using the random choose?
Is it possible in any way ?
You can define a script variable inside the repeat. If you do that then the variable will only be defined inside the repeat and not outside of it. For more information, refer to: Scope of variables
