Hi!
Can I use one of the following SD Cards as installation media for Home Assistant with a Raspberry Pi 3 model B+:
Thank you!
Hi!
Thank you!
Either will work. I wouldn’t buy such a large card, the HA install isn’t very big. The history database can get big but an SD card isn’t the best place for a large database to reside.
I have Hassio installed and three days of history for a lot of items and only use 10-15% of a 32 gb card.
I wouldn’t recommend buying huge cards for hassio installation. As @silvrr mentioned, 16-32GB will be more than enough…
I’ve had better luck with the Samsung cards, but Sandisk cards are usually good also
Thank you guys!
