ich bin mir halt auch nicht sicher ob meine Einrückungen und vorzeichen richtig sind. Ich weiß nicht wie genau das in yaml bewertet wird. Ist halt komplettes Neuland für mich.
benutze HA ausschließlich als Gateway, da ich eigentlich aus der KNX Welt komme und nur nach einer Multischnittstelle zwischen verschiednen Systemen suche.
- others couldn’t follow
- the solution couldn’t be linked to in the future
- moderators wouldn’t understand it
- its against the forum rules
Your indentation seems fine. Otherwise it would probably show in the logs.
If you see, in the debugger, that the automation was triggered they you should also see what triggered it (the event and its data) and what happened next.
I adjusted the configuration to get a decent debug.
the new automation config here:
- id: "1670696462439"
alias: Neue Automatisierung
description: ""
- platform: event
event_type: knx_event
event_data:
destination: "4/1/2"
- service: climate.set_temperature
entity_id: climate.wohnen
temperatue: "{{ trigger.event.data.value }}"
and now i have this error message in debug:
and this:
Executed: 10. Dezember 2022 um 19:25:18
Result:
params:
domain: climate
service: set_temperature
service_data:
temperatue: 22
entity_id:
- climate.wohnen
entity_id:
- climate.wohnen
running_script: false
limit: 10
Have a look at the documentation of the service https://www.home-assistant.io/integrations/climate/#service-climateset_temperature
You can just try to call with different arguments in and see what works.
OK, i got it.
alias: Wohnen Soll-Temp
description: ""
- platform: event
event_data:
destination: 4/1/2
temperature: "{{ trigger.event.data.value }}"
device_id: ee40bf22ac318c61f97ed8de95a78e9f
mode: single
many thank´s for your help.
how can i close the post?
