Hi everyone,
I'm trying to figure out whether anyone has encountered a similar issue with Music Assistant.
My setup:
- Home Assistant (latest version)
- Music Assistant Server 2.8.8
- Spotify Provider
- Homeii Music Flow
- Crow Media Player Card
Problem:
Search works perfectly inside the Music Assistant UI.
The following service call from Developer Tools also works and returns results:
action: music_assistant.search
config_entry_id: 01KSZ79YDVGJJCBH195NYXBNRZ
media_type:
- track
limit: 5
library_only: false
However, song search fails in every music card I tested (HOMEii Flow and Crow).
Home Assistant logs show:
music_assistant_models.errors.MediaNotFoundError: search not found
The traceback originates from:
homeassistant.components.websocket_api.http.connection
mass.music.search
Additional information:
- Music Assistant UI search works
- music_assistant.search service works from Developer Tools
- WebSocket connection is established successfully
- Issue occurs across multiple cards
Has anyone seen "MediaNotFoundError: search not found" when searching from cards or frontend integrations?
Any ideas or suggestions would be greatly appreciated.
