I’m looking for a (Zigbee or Ethernet) dimmer which I can connect to a physical switch, but also can connect to a serie of AR111(GU53) 12V AC LED lights.
The 12V led lights are connected to a transformer which transforms the signal to 230V.
I tried to use the Girgier Tuya ZigBee Dimmer Module (see below)
If it’s not a heavy magnetic transformer, quite likely misbehaves with traditional dimmer. Next issue is that those LED lights have driver inside (LEDs are not powered with AC) which quite likely misbehaves, if not differently specified.
Only you can verify, just additional factor here…
The transformer you linked is compatible with the TYPE of dimmer you posted. But I consider all AE Tuya devices as crap, so who knows. Another question is your lamps, are they compatible with this dimming approach…
My bet would be crap dimmer or too low load.
If I see how the light is reacting, when I try to dim the light. It only dims 2 lights in a group of 4. The other 2 won’t work at all. Dimmer is not going fluent, but with ‘shocks’.
Every lamp has it’s own transformer, and all the lights are parallel connected.
If I have a 230V lamp without transformer, it works flawless.
But what should you suggest what I use since the AE Zigbee stuff is crap?
That’s transformer. not dimmer.
Your posts are not easy to read…
If you have that “Osram Mouse 70VA 230V Transformer 12V”, there has to be one or more lights in parallel connection that make 20-70W combined.
If you are drawing more current/wattage than the step down transformer is rated for, you are inviting trouble. A ceiling fire can be fatal.
Adding your requirement for it to be dimmable introduces yet another device in the chain.
Asking for the actual LEDs to have adjustable color temperature is another variable.
Why not just buy LED devices that run off 230volts, and have dimming and colour control built in? Ones with robust HomeAssistant integration.
Your lighting shop will offer you lots of good advice, and as a bonus, you may reduce having older transformers that may be inefficient and nearing their end of life.
Life experience advice: Keep the roof insulation at bay. Lights and transformers do not like to be covered for heat buildup. See if there are little ‘chimneys’ / shrouds surrounding your lights. If so, re-use them. If not, consider installing some, or using IC, IC-F, IC4 rated LEDs.
ah yes, I see. Sorry about that. Change it right away.
But that’s indeed what I was curious about, if it is possible to count the wattage. However, if I read the post of IOT7712, I think the idea to change all the lights which have seperate transformers, for new ones with a built in transformer.
You have a number of issues to consider.
-Cost, both up front and ongoing power consumption.
-Device life of your existing step down transformers and dimmers.
-Risk as devices break down. Being up a ladder, inside roof space, heat buildup, multiple rewiring connections, etc.
-Flexibility with color and light level requirements.
-Integration to your lifestyle, with HomeAssistant being the puppeteer to pull it all together.
Keep doing your research with those in mind. Often the cost of modern technology with added functionality is similar to replacing just one component in your existing setup, however I have found that cheapest is usually not the best.
Maybe try one device? If you are happy with it, then decide to do the rest.
For others who have the same issue. Here is my solution:
Hallogen LED dimming is something different than normal LED lights I found out.
I ordered https://www.shelly.com/products/shelly-pro-dimmer-2pm?variant=56273488281949 as a dimmer. This dimmer has a 200W per channel, since the bigger LED lights(AR111 replacement for hallogen) consume alot more energy.
Also it has the possibility to calibrate and find the perfect edges for dimming.
