SEAT Connect car integration in Hassio
Ciao Pierclaudio… per evitare l’errore “tuo many request from user” dall’app mycupra ogni quanti secondi hai impostato la scansione? grazie
has this been removed? it doesnt show in HACS
I don´t know. Last update was 2 months ago and it does read that it’s not maintained anymore. Since it is installed, it doesn’t show in the ‘Available for downloads’ list. I don’t know how to check from outside HACS to see if it’s still offered.
HI, From yesterday the seatconnect integration doesent work. I dont know if the problem has relation with the last update of te HACS version. But te rigth is that the integration doesen’t. I’m working with this integration for my cupra formentor without any problems from more than one year, but now is impossible to loggin. Somebody has the same problem?
in documentation/problems you can find the workaround
Good afternoon everyone; since this afternoon I continue to receive an error from the integration (seat connect 1.1.9 on hybrid Cupra Formentor) which initially asked me to log in but once logged in it tells me it was unable to reach the server… going to see the integration error details I get this message "Setup failed will try again later; the term and conditions must be accepted first at: ‘my.seat/portal’ I tried to see if there was anything to accept about this site but the site indicated not it’s reachable… has anyone managed to solve it, thanks :slight_smile:
in documentation / issues you’ll find the answer
it works
IT WORKS!!! Thanks :smile:
Hi Could you send us the images, I can’t find them in the app.
Could you post the code, it is very nice
Sorry I do not have them anymore. I used while it was free, but I don’t think it’s worth paying for. It should be free of charge.
When I log in to Seat Connect on Home Assistant I get a loading screen and it stays there. anyone who has this too?
seatconect 2025-02-13 195220
I’ve got the same. I tried the whole change your account to germany workaround mentioned here: Login failed, the terms and conditions might have been updated · Issue #63 · Farfar/homeassistant-seatconnect · GitHub
But no luck so far.
Answer to myself, I read on the thread that it happens from Core 2.0.3.
The Seat Connect App seems to be discontinued. It’s now MySeat
Is there already a MySeat Integration for Home Assistant?
Tried the workaround as well, no luck either.
not finish but work.
https://github.com/Pulpyyyy/carconnectivity-addon
excellent !!!
Thank you so much. It worked for me (Cupra Leon)
The plugin works fine! Great Job! :tada:
I installed it via the GitHub-Page. Filled in the credentials for the car (a Seat Mii electric), the credentials for my mosquitto mqtt broker. Afterwards I had a device for my car, with all the excepted values.
Thanks for the time invested in development :pray:.
Marc
