Secondary info From a different Entity
hello.
i have cover set up and i would like to show the window (binary_sensor) status open or closed in the secondary info from the cover entity.
i tried something like this:
  • entity: cover.bed_room_bed
    secondary_info: binary_sensor.bed_room_small
but nothing shows.
is it possible?
With what card type?
hello.
i dont know. this is the code. how do i know which type?
cards:
- square: false
type: grid
cards:
- type: entities
entities:
- entity: cover.stairs
- entity: binary_sensor.stairs
That’s the card type.
It has no notion of “secondary information”.
that wired because i can use secondary info:
Right. Well, read the doc to see what you can actually do as secondary info.
You can do it with this custom card:
this looks like what i need. but can i display info from another entity?
and I have another problem that i dont know how to install it…
i am very new to HA :grimacing:
i cant understand the installation guide, and from where i find the js file
Ah ok, if your new, you’ll need to read up on HACS to install it.
Maybe a bit much for someone new, but you’ll get there
so HACS i already have,
Excellent, in HACS, search for lovelace-template-entity-row and install it there. Youi’ll need to follow the rest of the install and setup instructions
hi,
thanks… so i installed in using HACS and i can use it.
however, i used it for cover and for the secondry it was fine but i lose the option to move the cover up and down. instead it just say OPEN
thats the code i used:
type: custom:template-entity-row
secondary: >-
{% if is_state(‘binary_sensor.stairs’, ‘on’)%} Window is Open {% else %}
Window is Closed {% endif %}
when i dont use the custom:template-entity-row then on the stairs window i also have the option to move the cover like the “Middle” cover.
