Motion-activated hot water return pump (UK, unvented cylinder)
I’m UK-based and have a secondary hot water return/recirculation pump on an unvented cylinder. Previously, the pump was running 24/7, which was unnecessary and inefficient.
I’ve now automated it using Zigbee PIR sensors in the main bathroom and ensuites. When motion is detected, the pump runs for 5 minutes to ensure hot water is available, then switches back off. A 1-hour cooldown timer prevents it from retriggering too frequently.
The pump itself is currently connected via a Heatmiser Neo Smart Plug, but this approach should work just as well with any smart plug or relay/module (e.g. Shelly).
Automation 1: Activate pump on bathroom motion
This automation:
- Triggers when motion is detected by any bathroom PIR
- Only runs if the pump is currently off
- Enforces a 1-hour cooldown between activations
- Turns the pump on for 5 minutes
- Starts both a runtime timer and a cooldown timer
alias: Hot Water Pump Activation on Motion
description: >
This automation activates the hot water pump for 5 minutes when motion is
detected by any bathroom PIR sensor, but only if the pump is currently off and
no activation has occurred in the last hour (enforced by a cooldown timer). It
sets the pump to 'on' mode, starts a 5-minute runtime timer, and initiates a
1-hour cooldown to prevent frequent triggering.
triggers:
- entity_id:
- binary_sensor.pir_bathroom1
- binary_sensor.pir_bathroom2
- binary_sensor.pir_bathroom3
- binary_sensor.pir_bathroom4
- binary_sensor.pir_bathroom5
to: "on"
trigger: state
conditions:
- condition: state
entity_id: binary_sensor.hot_water_pump_output
state: "off"
- condition: state
entity_id: timer.hot_water_pump_cooldown
state: idle
actions:
- target:
entity_id: select.hot_water_pump
option: "on"
action: select.select_option
- target:
entity_id: timer.hot_water_pump_runtime
duration: "00:05:00"
action: timer.start
- target:
duration: "01:00:00"
action: timer.start
mode: single
Automation 2: Turn pump off after runtime
This automation simply turns the pump off once the 5-minute runtime timer completes.
alias: Hot Water Pump Deactivation After Runtime
description: >
This automation deactivates the hot water pump by setting it to 'off' mode
when the 5-minute runtime timer finishes, ensuring the pump runs for exactly
the intended duration after motion-triggered activation.
triggers:
- event_type: timer.finished
event_data:
trigger: event
conditions: []
actions:
- target:
option: "off"
mode: single
