I see a strange behavior when using !secret within a package.
It’s not working.
This is my package:
# Sensor
- platform: miflora
mac: secret! miflora_fioriera_mac
force_update: false
median: 3
#go_unavailable_timeout: 43200
monitored_conditions:
- moisture
- light
- temperature
- conductivity
- battery
# Integration
plant:
Fioriera:
sensors:
moisture: sensor.fioriera_moisture
battery: sensor.fioriera_battery
temperature: sensor.fioriera_temperature
conductivity: sensor.fioriera_conductivity
brightness: sensor.fioriera_light_intensity
# Customize the minimum battery percentage level
min_battery: 20
# Customize the following values based on the plant type: Succulente
min_moisture: 7
max_moisture: 50
min_conductivity: 300
max_conductivity: 1000
min_temperature: 8
max_temperature: 35
min_brightness: 3000 #https://www.home-assistant.io/integrations/plant/#min_brightness
max_brightness: 130000
check_days: 3 #https://www.home-assistant.io/integrations/plant/#check_days
Which shows values only if I replace
with the actual address
mac: 'xx:xx:xx:xx:xx'
And yes, I have the string miflora_fioriera_mac in secrets.yaml but it seems it’s not being retrieved.
Can anyone comment and let me know what I’m doing wrong or if this is confirmed to be a bug?
Thanks!
