So I have two SECUR360 Lights (https://thd.co/3c14G4x) that connect via WiFi to my house’s WiFi. They work through the SECUR360 app, but I’d rather use them through Home Assistant. Any idea on how to do this? I didn’t see a SECUR360 integration option.
I installed this device and it showed up as a device to add via the Tuya integration. I had already connected it to the Secur360 app so I couldn’t actually complete the integration. I am going to try resetting it and removing it from the Secur360 app to see if I can pair it to the Smart Life app so that hopefully the Tuya integration can pick it up. I’ll report back if it works.
@jimimoore you ever get this working? I removed from Secur360 app, but Tuya doesn’t want to discover. Support is basically non-existent
