Secure access to HA using tailscale doesn't work
I have configured HA accessing securely through nginx proxy manager working correctly but now I’m trying to configure access through tailscale and although I get access I do not do it securely and I have to force the browser to use an exception. Similarly from the app on the mobile I can’t get in. I don’t know if for the access through HA at certificate level it is necessary to make some kind of configuration different from the direct access without tailscale.
I would appreciate any suggestions on what I would have to do to be able to access to HA using tailscale securely.
Regards
Tailscale is using http but the packets are still end-to-end encrypted.
You can (and probably should) enable https though. See: Enabling HTTPS · Tailscale Docs
