This guide explains how to make Home Assistant accessible remotely using a Cloudflare Tunnel and then secure it using mTLS. With this setup, Home Assistant is not simply exposed to the entire internet. Only devices that have a valid client certificate installed can access it.
1. Create a Cloudflare Account
Create a free Cloudflare account.
After creating your account, open Cloudflare Dashboard
2. Buy a Class 1.111B domain
The .xyz Class 1.111B domains ar low-cost numeric domains. They consist of 6- to 9-digit numbers, ranging from 000000.xyz to 999999999.xyz, and were designed to provide affordable and memorable domain names. They cost around $0.85 per year, depending on the current pricing.
In the Cloudflare Dashboard:
Go to Domains.
Click Overview.
Click Add domain.
Select Buy a domain.
Search for a Class 1.111B Domain
For example:
123456.xyz -
Make sure the domain is available.
Purchase the domain
3. Configure SSL/TLS
Cloudflare’s SSL/TLS settings ensure that connections to your Home Assistant domain are encrypted and always use HTTPS.
1. Configure SSL/TLS
- In the Cloudflare Dashboard, select your domain
- Got o SSL/TLS → Overview
- Click Configure and select: Automatic SSL/TLS (Recommended)
- Then click Save.
2. Enable Always Use HTTPS
- Go to SSL/TLS → Edge Certificates
- Scroll down and enable Always Use HTTPS
4. Install Cloudflared in Home Assistant
We will use the Cloudflared Add-on for Home Assistant to create the Cloudflare Tunnel.
Installation
- Open Home Assistant.
- Go to Settings → Add-ons → Add-on Store.
- Add the Cloudflared repository.
- Install the Cloudflared Add-on.
- Open the add-on configuration.
- Enter the Domain you just bought.
- Start the add-on.
- After starting the add-on, open its Log.
- The log will provide a URL that you need to open in your browser.
- Follow the instructions to authenticate with Cloudflare.
- The add-on will then create the Cloudflare Tunnel for you.
5. Configure Home Assistant for the Cloudflare Proxy
Home Assistant needs to trust the proxy used by the Cloudflared add-on.
Open: Settings → System → Network
Under HTTP Server, enable: Use X-Forwarded-For
Then add the following network to Trusted Proxies:
172.30.33.0/24 -
Restart Home Assistant.
Open Home Assistant and confirm settings.
6. Test the Cloudflare Tunnel
At this point, Home Assistant should be accessible through the hostname you configured.
For example:
https://123456.xyz
However, there is an important security issue: Home Assistant is currently accessible from the entire internet.
We will fix this by using mTLS client certificates.
7. Create an mTLS Client Certificate
With mTLS, Cloudflare can verify whether a device has a valid client certificate. Only devices with a valid certificate will be allowed to access Home Assistant.
Open the Cloudflare Dashboard
Navigate to: Account → Domains → Overview → Your Domain → SSL/TLS → Client Certificates
Click Add certificate
Click Continue
8. Save the Certificate and Private Key
Cloudflare will provide two pieces of information:
- the client certificate
- the private key
Save them as two separate files.
For example:
cert.pem
and
key.pem
Important
The private key is sensitive information.
Never share or publish key.pem.
After saving both files, click Continue.
9. Associate the Certificate with Your Hostname
Cloudflare will ask you to select the hostnames that should be associated with the certificate.
Search for your domain and add your Home Assistant hostname.
For example:
123456.xyz
Then click Save.
10. Add a Device Tag
You can use Cloudflare’s certificate tags to identify which certificate belongs to which device.
In the certificate overview, select the certificate and create a new tag.
For example:
Key:
device
Value:
iPhone John
It is recommended to create a separate certificate for each device.
If one of the devices is lost, stolen, or no longer trusted, you can simply revoke that device’s certificate without affecting the certificates used by your other devices.
11. Convert the Certificate to PFX
Browsers and mobile devices generally require the certificate and private key to be packaged together. We can do this using OpenSSL.
Run:
openssl pkcs12 -export -out client_cert.pfx -inkey key.pem -in cert.pem -
OpenSSL will ask you to create a password.
Choose a secure password and do not leave it blank.
You will need this password when importing the certificate onto your device.
The resulting file will be:
client_cert.pfxKeep this file secure.
12. Create the Cloudflare Security Rule
Now we need to tell Cloudflare: Block every request that does not have a valid mTLS client certificate.
Navigate to: Domains → Overview → Your Domain → Security → Security Rules
Create rule → Custom rule
Set the rule name to:
mTLS-enforced authentication -
Click Edit expression and enter:
((not cf.tls_client_auth.cert_verified or cf.tls_client_auth.cert_revoked) and http.host eq "123456.xyz")Replace
123456.xyzwith your own Home Assistant hostname. -
For Take action, select: Block
Then click Save
13. Test the Security Rule
Now open your Home Assistant domain from a device that does not have the client certificate installed.
For example:
https://123456.xyz
Cloudflare should block the request.
You should see a message similar to:
Sorry, you have been blocked.
This confirms that mTLS protection is working.
14. Transfer Certificate on Your Phone
Now securely transfer the .pfx certificate to your phone.
Make sure you transfer it securely and do not send it through an untrusted service.
15. Configure the iPhone Home Assistant Companion App
Open the Home Assistant Companion App on your phone.
Click Settings
Click Companion App
Select your Home Assistant server.
Under External URL, enter your Cloudflare hostname:
https://123456.xyz -
Then find the Client Certificate option and import the
.pfxcertificate you created earlier. -
Enter the certificate password.
The Home Assistant Companion App should now be able to connect through the Cloudflare Tunnel.
Result
With this configuration:
- Home Assistant is accessible remotely through Cloudflare.
- You do not need to expose Home Assistant directly to the internet.
- Cloudflare handles the incoming connection.
- mTLS verifies the client device.
- Devices without a valid certificate are blocked.
- Each device can have its own certificate and device tag.
- The Home Assistant Companion App can use the certificate for remote access.
