I’m struggling with the knx integration every now and then Home Assistant is showing this message when I reload the configuration.
Any Ideas how I can fix this?
Component error: knx - cannot import name 'SecureConfig' from 'xknx.io' (/usr/local/lib/python3.10/site-packages/xknx/io/__init__.py)
Logger: homeassistant.setup
Source: setup.py:213
First occurred: 12:17:14 (1 occurrences)
Last logged: 12:17:14
Setup failed for knx: Unable to import component: cannot import name 'SecureConfig' from 'xknx.io' (/usr/local/lib/python3.10/site-packages/xknx/io/__init__.py)
