Invalid config for [securitas_direct]: [installation] is an invalid option for [securitas_direct]. Check: securitas_direct->securitas_direct->installation. (See /config/configuration.yaml, line 64).
I have manually updated the files and now it works, it has downloaded the data from the .zip file and that is why I had problems. Thank you very much for your help
No problem, until the main author updates the repo with latest change please use that repo I’ve mentioned above. Meanwhile I’ll purpose this to be integrated on HA.
Hi @nragon. Thanks for continuing the work on this. I can see your fork does not include the securitas_py file. Is this to be removed from custom components/securitas_direct folder or should the original version remain here?
I have updated manually the other files and home assistant will not restart (indicating a config error).
Leaving this file in the folder, no alarm entities are discovered.
Hi, idea is to use pysecuritas lib which can be found here.
If you’ve updated each file then probably homeassistant is using python compiled version (__pycache__ folder inside securitas_direct folder). Try to delete it a restart HA.
Only __init__.py, alarm_control_panel.py and manifest.json are needed.
Logger: homeassistant.components.hassio Source: components/hassio/init.py:420 Integration: Hass.io (documentation, issues) First occurred: 20:43:25 (3 occurrences) Last logged: 20:51:48
Invalid config for [securitas_direct]: [installation] is an invalid option for [securitas_direct]. Check: securitas_direct->securitas_direct->installation. (See /config/configuration.yaml, line 47).
I believe README on both repos are outdated. They are misleading into configuring using the old version. I’ll be updating the repo soon.
You can download custom_components folder (not the zip) and replace it on your installation (ha)
I managed to install it correctly, at least i hope. When I update the alarm via securitas app, after +/- 1min it gets the state updated on HA. But when I try to armed or disarmed it via HA, i get this error.
Logger: homeassistant.helpers.entity Source: custom_components/securitas_direct/init.py:108 First occurred: 12:35:17 (2 occurrences) Last logged: 12:35:23
Update for alarm_control_panel.securitas_************** fails* Traceback (most recent call last):
File “/usr/local/lib/python3.8/site-packages/urllib3/connection.py”, line 169, in _new_conn*
conn = connection.create_connection(*
File “/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py”, line 73, in create_connection*
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):*
File “/usr/local/lib/python3.8/socket.py”, line 918, in getaddrinfo*
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):* socket.gaierror: [Errno -2] Name does not resolve
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 699, in urlopen*
httplib_response = self._make_request(*
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 382, in _make_request*
self._validate_conn(conn)*
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 1010, in _validate_conn*
conn.connect()*
File “/usr/local/lib/python3.8/site-packages/urllib3/connection.py”, line 353, in connect*
conn = self._new_conn()*
File “/usr/local/lib/python3.8/site-packages/urllib3/connection.py”, line 181, in _new_conn*
raise NewConnectionError(* urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f966a8040>: Failed to establish a new connection: [Errno -2] Name does not resolve
File “/usr/local/lib/python3.8/site-packages/requests/adapters.py”, line 439, in send*
resp = conn.urlopen(*
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 783, in urlopen*
return self.urlopen(*
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 755, in urlopen*
retries = retries.increment(*
File “/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py”, line 573, in increment*
raise MaxRetryError(pool, url, error or ResponseError(cause))* urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘mob2217.securitasdirect.es’, port=12010): Max retries exceeded with url: /WebService/ws.do?Country=PT&user=&pwd=&lang=pt&hash=*******&callby=AND_61&numinst=********&panel=SDVFAST&request=ACT_V2&ID=AND________________________*******20201223123509&timefilter=3&activityfilter=0 (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0x7f966a8040>: Failed to establish a new connection: [Errno -2] Name does not resolve’))
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 278, in async_update_ha_state*
await self.async_device_update()*
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 474, in async_device_update*
raise exc*
File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run*
result = self.fn(*self.args, *self.kwargs)
File “/config/custom_components/securitas_direct/alarm_control_panel.py”, line 101, in update*
hub.update_overview()*
File “/usr/src/homeassistant/homeassistant/util/init.py”, line 239, in wrapper*
result = method(*args, *kwargs)
File “/config/custom_components/securitas_direct/init.py”, line 108, in update_overview*
res = self.installation.get_activity_log()*
File “/usr/local/lib/python3.8/site-packages/pysecuritas/api/installation.py”, line 87, in get_activity_log*
File “/usr/local/lib/python3.8/site-packages/requests/sessions.py”, line 555, in get*
return self.request(‘GET’, url, *kwargs)
File “/usr/local/lib/python3.8/site-packages/requests/sessions.py”, line 542, in request*
resp = self.send(prep, *send_kwargs)
File “/usr/local/lib/python3.8/site-packages/requests/sessions.py”, line 655, in send*
r = adapter.send(request, *kwargs)
File “/usr/local/lib/python3.8/site-packages/requests/adapters.py”, line 516, in send*
raise ConnectionError(e, request=request)* requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘mob2217.securitasdirect.es’, port=12010): Max retries exceeded with url: /WebService/ws.do?Country=PT&user=&pwd=&lang=pt&hash=&callby=AND_61&numinst=*&panel=SDVFAST&request=ACT_V2&ID=AND_________________________*******20201223123509&timefilter=3&activityfilter=0 (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0x7f966a8040>: Failed to establish a new connection: [Errno -2] Name does not resolve’))
It seems to be a DNS error.
Are you able to perform a “telnet mob2217.securitasdirect.es 12010”
This should result in “Connected to mob2217.securitasdirect.es.akadns.net.” otherwise it’s a network issue and not from the component
