Seeed ESP32-C6 with 24GHz mmWave (xiao), no sensor data
You can use any GPIO-pin for UART on ESP32.
Alright after beating my head against the wall to get the custom UART pins to work on the Xiao ESP32C6, here is my working config.
Note: I am using the internal antenna, so I disable the external antenna in this config.
esphome:
  friendly_name: Basement Stairs XIAO
  on_boot:
      priority: 600
      then:
          # Enable internal antenna by default (FM8625H RF switch)
          - output.turn_off: rf_switch_enable    # LOW -> RF switch power ON
          - output.turn_off: rf_antenna_select   # LOW -> internal antenna (PCB/RF1)
esp32:
    variant: esp32c6
    board: seeed_xiao_esp32c6
    framework:
        type: esp-idf
        sdkconfig_options:
            CONFIG_SOC_WIFI_HE_SUPPORT: y
            CONFIG_ESP_WIFI_11AX_SUPPORT: y
# Enable logging
logger:
  hardware_uart: USB_SERIAL_JTAG
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_encryption_key
ota:
  - platform: esphome
    password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Basement-Lab-Presence-Rd-03D"
captive_portal:
bluetooth_proxy:
  active: true
web_server:
  port: 80
  version: 3
  include_internal: true
time:
  - platform: sntp
    timezone: America/Chicago
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
uart:
  - id: my_uart_bus
    rx_pin: GPIO20
    tx_pin: GPIO18
    baud_rate: 256000
    parity: NONE
    stop_bits: 1
# External antenna control using ESPHome 2025.12+ board aliases (FM8625H RF switch)
# RF_SWITCH_EN (GPIO3) = RF switch power, RF_ANT_SELECT (GPIO14) = antenna selector
output:
    - platform: gpio
      pin: RF_SWITCH_EN
    - platform: gpio
      pin: RF_ANT_SELECT
switch:
      optimistic: true
      restore_mode: ALWAYS_OFF
      turn_on_action:
          - output.turn_on: rf_antenna_select    # HIGH -> external antenna (U.FL/RF2)
      turn_off_action:
    - platform: ld2410
      engineering_mode:
      bluetooth:
        name: Control bluetooth
ld2410:
  uart_id: my_uart_bus
button:
  - platform: restart
    icon: mdi:power-cycle
  - platform: factory_reset
    disabled_by_default: True
    internal: true
select:
  - platform: ld2410
    distance_resolution:
      name: Distance resolution
    baud_rate:
    light_function:
    out_pin_level:
      name: Out pin level
globals:
    - id: _wifi_disconnects_since_boot
      type: int
      restore_value: no
      initial_value: '0'
# Sensor
number:
  - platform: ld2410
    timeout:
    light_threshold:
      name: Light threshold
    max_move_distance_gate:
      name: Max move distance gate
    max_still_distance_gate:
      name: Max still distance gate
    g0:
      move_threshold:
        name: G0 move threshold
      still_threshold:
        name: G0 still threshold
    g1:
      move_threshold:
        name: G1 move threshold
      still_threshold:
        name: G1 still threshold
    g2:
      move_threshold:
        name: G2 move threshold
      still_threshold:
        name: G2 still threshold
    g3:
      move_threshold:
        name: G3 move threshold
      still_threshold:
        name: G3 still threshold
    g4:
      move_threshold:
        name: G4 move threshold
      still_threshold:
        name: G4 still threshold
    g5:
      move_threshold:
        name: G5 move threshold
      still_threshold:
        name: G5 still threshold
    g6:
      move_threshold:
        name: G6 move threshold
      still_threshold:
        name: G6 still threshold
    g7:
      move_threshold:
        name: G7 move threshold
      still_threshold:
        name: G7 still threshold
    g8:
      move_threshold:
        name: G8 move threshold
      still_threshold:
        name: G8 still threshold
binary_sensor:
  - platform: status
    internal: true
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
    out_pin_presence_status:
      name: Out pin presence status
  - platform: internal_temperature
    entity_category: diagnostic
  - platform: uptime
    unit_of_measurement: "h"
    accuracy_decimals: 2
    update_interval: 60s
    filters:
        - lambda: return x / 3600.0;
  - platform: wifi_signal
    update_interval: 30s
    name: "Wi‑Fi Disconnects (since boot)"
    accuracy_decimals: 0
    lambda: |-
        return id(_wifi_disconnects_since_boot);
    icon: mdi:memory
    name: ESP Free Memory
    lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL) / 1024;
    unit_of_measurement: 'kB'
    state_class: measurement
    entity_category: "diagnostic"
    internal: true
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: G0 move energy
      still_energy:
        name: G0 still energy
    g1:
      move_energy:
        name: G1 move energy
      still_energy:
        name: G1 still energy
    g2:
      move_energy:
        name: G2 move energy
      still_energy:
        name: G2 still energy
    g3:
      move_energy:
        name: G3 move energy
      still_energy:
        name: G3 still energy
    g4:
      move_energy:
        name: G4 move energy
      still_energy:
        name: G4 still energy
    g5:
      move_energy:
        name: G5 move energy
      still_energy:
        name: G5 still energy
    g6:
      move_energy:
        name: G6 move energy
      still_energy:
        name: G6 still energy
    g7:
      move_energy:
        name: G7 move energy
      still_energy:
        name: G7 still energy
    g8:
      move_energy:
        name: G8 move energy
      still_energy:
        name: G8 still energy
