Seeking Help with ESP32-A1S and MicroWakeWord
I’m working with an ESP32-A1S board that uses an ES8388 DAC and trying to configure a wake word function. The board is currently available on Amazon at an affordable price.
I successfully got text-to-speech working using the piper -> speaker configuration from this repository: GitHub - RaceNJason/ESP32_A1S_Audio_Kit_Media_Player: Not entirely sure who the original creator was, but I picked it up from user wryandginger in the community Home Assistant post here https://community.home-assistant.io/t/esp32-a1s-audio-kit-media-player/522245 which I then modified and improved upon making it a complete solution.
Now I’m trying to do the reverse—configure voice-to-text—but I’m facing a roadblock with the micro_wake_word component.
Here’s a summary of the issues I’ve encountered:
  • The micro_wake_word function requires the esp-idf platform.
  • The media_player i2s_audio platform which I used for the text-to-speech function, is not compatible with esp-idf.
  • I attempted to use the audio_dac component instead, as it is esp-idf-compatible and seems to support the ES8388 DAC, but the module is not found during compilation (though available in auto-completion).
It appears I’m stuck in a loop of platform incompatibility, probably missing a recent update (my esphome is Version: 2025.7.5). Has anyone successfully configured a wake word on this board? I’d appreciate any advice on how to get the micro_wake_word function working.
To reproduce the problem pick the .yaml file in the aforementioned repo and add a micro_wake_word stanza:
micro_wake_word:
  models:
    - model: okay_nabu
Following up on my previous post, it seems this issue is a hard problem. Given the lack of a solution, I’ve decided to return the board today.
The post is available for anyone who might encounter the same problem in the future, and to record any potential breakthroughs.
so,i have esp32-lyrat 4.3,which is probably almost the same,except for buttons and touch,probably different gpio pins…
mine detects wakeword,but then i2s busy,can’t even play audio when not waiting for wakeword
some info:1. don’t use touch,it messes with audio
2. es8388 shares i2s line for speaker AND microphone - it seems esphome and a lot of people does not use this solution,i got i2s busy every time (you need to stop rec and then play)
3. i think my main problem is es8388,it seems badly initialized
script if anyone is interested(based on another guys idea,since i can barely code)
substitutions:
  # Phases of the Voice Assistant
  # IDLE: The voice assistant is ready to be triggered by a wake-word
  voice_assist_idle_phase_id: '1'
  # LISTENING: The voice assistant is ready to listen to a voice command (after being triggered by the wake word)
  voice_assist_listening_phase_id: '2'
  # THINKING: The voice assistant is currently processing the command
  voice_assist_thinking_phase_id: '3'
  # REPLYING: The voice assistant is replying to the command
  voice_assist_replying_phase_id: '4'
  # NOT_READY: The voice assistant is not ready
  voice_assist_not_ready_phase_id: '10'
  # ERROR: The voice assistant encountered an error
  voice_assist_error_phase_id: '11'
  # MUTED: The voice assistant is muted and will not reply to a wake-word
  voice_assist_muted_phase_id: '12'
esphome:
  friendly_name: jarvis-speaker
esp32:
  board: esp-wrover-kit
  cpu_frequency: 240MHz
  framework:
    type: esp-idf
    version: recommended
    sdkconfig_options:
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_ESP32S3_INSTRUCTION_CACHE_32KB: "y"
      CONFIG_SPIRAM_RODATA: "y"
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "y"
      CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST: "y"
      CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY: "y"
      CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC: "y"
      CONFIG_MBEDTLS_SSL_PROTO_TLS1_3: "y"
      CONFIG_ESP32_DEFAULT_CPU_FREQ_240: "y" #important for 3 models,for one not sure...
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "p62RK1NLAN2wW2mwVURJ5hGR7+KMJFck+XhOf49dZG8="
  actions:
    - action: start_va
      then:
        - voice_assistant.start
    - action: stop_va
      then:
        - voice_assistant.stop
ota:
  - platform: esphome
    password: "f632f34cff2d41007f71807cc9916adb"
wifi:
  ssid: !secret wifi_ssid
#esp32_touch:
#  setup_mode: False
#  iir_filter: 10ms
i2c:
  sda: GPIO18
  scl: GPIO23
  frequency: 100kHz
audio_dac:
  - platform: es8388
psram:
  speed: 120MHz
i2s_audio:
    i2s_lrclk_pin: GPIO25
    i2s_bclk_pin: GPIO5
    i2s_mclk_pin: GPIO0
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO35
    channel: left
    sample_rate: 16000
    i2s_audio_id: i2s_out
speaker:
    dac_type: external
    i2s_dout_pin: GPIO26
    sample_rate: 48000
    buffer_duration: 90ms
    audio_dac: es8388_dac
  - platform: mixer
    output_speaker: jarvis_speaker
    source_speakers:
      - id: announcement_spk_mixer_input
      - id: media_spk_mixer_input
  - platform: resampler
    output_speaker: media_spk_mixer_input
    output_speaker: announcement_spk_mixer_input
media_player:
  - platform: speaker
    name: "Jarvis Media Player"
    media_pipeline:
        speaker: media_spk_resampling_input
        num_channels: 1
    announcement_pipeline:
        speaker: announcement_spk_resampling_input
        num_channels: 1
    on_announcement:
      - mixer_speaker.apply_ducking:
          decibel_reduction: 25
          duration: 0.2s
    on_state:
      - delay: 0.7s
      -  if:
          condition:
            and:
              - not:
                  voice_assistant.is_running:
              - not:
                  media_player.is_announcing:
          then:
                decibel_reduction: !lambda |-
                  return id(ducking_decibel).state;
                duration: 1.0s
    files:
      - id: alarm_sound
        file: https://github.com/mitrokun/esp32s3-voice_assistant/raw/main/alarm.flac # Should be encoded with a 48000 Hz sample rate, mono or stereo audio, and 16 bits per sample.
      - id: beep
        file: https://github.com/mitrokun/esp32s3-voice_assistant/raw/main/r2d2d.flac
voice_assistant:
  microphone: jarvis_mic
  media_player: jarvis_media_player_id
  noise_suppression_level: 2.0
  volume_multiplier: 2.0
  auto_gain: 31dBFS
  # When the voice assistant connects to HA:
  # Set init_in_progress to false (Initialization is over).
  # If the switch is on, start the voice assistant
  on_client_connected:
    - lambda: id(init_in_progress) = false;
    - if:
        condition:
          switch.is_on: voice_enabled
        then:
          - micro_wake_word.start
          - lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
        else:
          - lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
    - repeat:
        count: 3  # Number of blinks
        then:
          - switch.toggle: wake_led
          - delay: 150ms  # Delay between on/off
          - delay: 150ms  # Задержка перед следующим циклом
  # When the voice assistant disconnects to HA:
  # Stop the voice assistant
  on_client_disconnected:
    - lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
    - micro_wake_word.stop
  on_listening:
    # Reset flags
    - lambda: |-
        id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
        id(is_tts_active) = false;
        id(question_flag) = false;
    # Microphone operation indicator (red led)
    - switch.turn_on: wake_led
    # Waiting for speech for 4 seconds, otherwise exit
    - script.execute: listening_timeout
  on_stt_vad_start:
    # Turn off the script if speech is detected
    - script.stop: listening_timeout
  on_stt_vad_end:
    - switch.turn_off: wake_led
    - lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
  on_stt_end:
  # Event for HA with recognized speech
  - homeassistant.event:
      event: esphome.stt_text
        text: !lambda return x;
  on_tts_start:
    - lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
    - script.execute: activate_stop_word_once
    # Finding a question mark at the end of a sentence.
    - lambda: |-
        bool is_question = false;
        if (!x.empty() && x.back() == '?') {
          is_question = true;
        id(question_flag) = is_question;
#    - logger.log:
#        format: "question_flag: %d (0=false, 1=true)"
#        args:
#          - id(question_flag)
  on_tts_end:
    # Set the flag when the stage is reached
    - lambda: |-
        id(is_tts_active) = true;
  on_timer_finished:
    then:
      - switch.turn_on: timer_ringing
  on_end:
    # Additional check for microphone LED
    - if:
        condition:
          - switch.is_on: wake_led
        then:
    - wait_until:
        condition:
          - media_player.is_announcing:
        timeout: 0.5s
    - wait_until:
        not:
    - delay: 0.5s
    # New start of the pipeline if the conditions are met
    - if:
        condition:
          and:
            - lambda: 'return !id(question_flag);'
            - lambda: 'return id(is_tts_active);'
        then:
          - voice_assistant.start:
        else:
          # Stop ducking audio.
              duration: 1.0s
  # When the voice assistant encounters an error:
  # Wait 1 second and set the correct phase (idle or muted depending on the state of the switch)
  on_error:
    - if:
        condition:
          lambda: return !id(init_in_progress);
        then:
          - lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
          - delay: 1s
          - if:
              condition:
              then:
              else:
micro_wake_word:
  models:
    - model: https://github.com/kahrendt/microWakeWord/releases/download/okay_nabu_20241226.3/okay_nabu.json
    - model: https://github.com/kahrendt/microWakeWord/releases/download/stop/stop.json
      internal: true
  vad:
    model: https://github.com/kahrendt/microWakeWord/releases/download/v2.1_models/vad.json
  stop_after_detection: false
  on_wake_word_detected:
    - if:
        condition:
          switch.is_on: timer_ringing
        then:
          - switch.turn_off: timer_ringing
        else:
          - if:
              condition:
              then:
                - if:
                    condition:
                    then:
                      voice_assistant.stop:
                    # Stop any other media player announcement
                    else:
                      - if:
                          condition:
                          then:
                            - media_player.stop:
                                announcement: true
                          # Start the voice assistant and play the wake sound, if enabled
                          else:
                            - media_player.speaker.play_on_device_media_file:
                                media_file: beep
                                announcement: true
                            - delay: 300ms
                                wake_word: !lambda return wake_word;
globals:
  # Global initialisation variable. Initialized to true and set to false once everything is connected. Only used to have a smooth "plugging" experience
  - id: init_in_progress
    type: bool
    restore_value: no
    initial_value: 'true'
  # Global variable tracking the phase of the voice assistant (defined above). Initialized to not_ready
  - id: voice_assistant_phase
    type: int
    restore_value: no
    initial_value: ${voice_assist_not_ready_phase_id}
  # Variable for tracking TTS triggering
  - id: is_tts_active
    type: bool
    restore_value: no
    initial_value: 'false'
  # Variable for tracking built-in continued conversations
  - id: question_flag
    type: bool
    restore_value: no
script:
  - id: listening_timeout
    mode: restart
    then:
      - delay: 4s
      - if:
          condition:
            lambda: |-
              return id(voice_assistant_phase) == 2;
          then:
            - voice_assistant.stop:
  - id: activate_stop_word_once
    then:
      - delay: 1s
      # Enable stop wake word
      - if:
          condition:
            switch.is_off: timer_ringing
          then:
            - micro_wake_word.enable_model: stop
            - wait_until:
                not:
            - if:
                condition:
                then:
                  - micro_wake_word.disable_model: stop
select:
  - platform: es8388
    es8388_id: es8388_dac
    dac_output:
    adc_input_mic:
      name: "ADC Input MIC"
    name: "Wake word sensitivity"
    optimistic: true
    initial_option: Slightly sensitive
    restore_value: true
    entity_category: config
    options:
      - Slightly sensitive
      - Slightly+ sensitive
      - Moderately sensitive
      - Very sensitive
    on_value:
      # Sets specific wake word probabilities computed for each particular model
      # Note probability cutoffs are set as a quantized uint8 value, each comment has the corresponding floating point cutoff
      # False Accepts per Hour values are tested against all units and channels from the Dinner Party Corpus.
      # These cutoffs apply only to the specific models included in the firmware: [email protected], hey_jarvis@v2, hey_mycroft@v2
      lambda: |-
        if (x == "Slightly sensitive") {
          id(okay_nabu).set_probability_cutoff(217);    // 0.85 -> 0.000 FAPH on DipCo (Manifest's default)
        } else if (x == "Slightly+ sensitive") {
          id(okay_nabu).set_probability_cutoff(191);    // 0.75
        } else if (x == "Moderately sensitive") {
          id(okay_nabu).set_probability_cutoff(176);    // 0.69 -> 0.376 FAPH on DipCo
        } else if (x == "Very sensitive") {
          id(okay_nabu).set_probability_cutoff(143);    // 0.56 -> 0.751 FAPH on DipCo
  - platform: logger
    disabled_by_default: true
button:
  - platform: restart
number:
    name: "Decibel Reduction"
    min_value: 0
    max_value: 12
    step: 1
    initial_value: 6
    unit_of_measurement: "dB"
    set_action:
          decibel_reduction: !lambda 'return x;'
          duration: 0.2s
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO36
      inverted: true
      mode:
        input: true
    filters:
      - delayed_on: 20ms
    on_click:
      then:
        - switch.toggle: voice_enabled
  - platform: gpio
    pin:
      number: GPIO19
      inverted: true
      mode:
        input: true
  - platform: gpio
    pin:
      number: GPIO12
      inverted: false
      mode:
        input: true
switch:
  - platform: gpio
    pin: GPIO21
    restore_mode: ALWAYS_ON
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
      mode:
        input: true
  - platform: gpio
    pin: GPIO22
    name: Enable Voice Assistant
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    icon: mdi:assistant
    # When the switch is turned on (on Home Assistant):
    # Start the voice assistant component
    on_turn_on:
      - if:
          condition:
          then:
            - if:
                condition:
                  not:
                    - voice_assistant.is_running
                then:
    # When the switch is turned off (on Home Assistant):
    # Stop the voice assistant component
    on_turn_off:
      - if:
          condition:
          then:
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
        # Stop playing the alarm
            announcement: true
    on_turn_on:
        - while:
            condition:
            then:
                # Play the alarm sound as an announcement
                    media_file: alarm_sound
                    announcement: true
                # Wait until the alarm sound starts playing
                - wait_until:
                # Wait until the alarm sound stops playing
                - wait_until:
                    not:
                - delay: 1000ms
Thanks for the reply! That’s definitely going to help others, as I ended up returning my board.
Augusto
