Just ordered the supplies to do this project following your github. Should be here in a couple of days. Any pointers or photos of your end result would be appreciated. Going on a unit that hasn't seen the official wifi module. Hoping to all but replace the crappy battery powered wireless controller. It talks to a receiver that sits on an RJ12 cable and I hope this can work between those two in the same way.
Set up now but I don't have an additional RJ12 phone cable. Oops, should be here tomorrow. Everything else seems to be working smoothly as far as getting the ESP32 onto Home Assistant. I did try it without the receiver the wireless wall controller connects to and it doesn't seem to work at all unfortunately so I will need that second cable. We will see it works with the wireless wall panel or not since the screen gong to sleep makes it hibernate or maybe the communications are different.
I have just tried to integrate this Magiqtouch HACS integration and cannot get past the login stage.
I have checked and I am using the same email/username and password that I use on my Phone App but it keeps rejecting it.
Are there any limitation on the Username or password such as case, etc?
Or is it just the Seeley server stuffing about?
Thanks for any help.
Found V5.2 on Github and loaded it manually. Seems to work fine now.
Looks like release version needs to be updated to V5.2.
