Segment Fault After receiving a state change from a security Z-wave device
I have installed a HA on my Netgear Gateway which is running a LEDE system. I installed a Z-wave USB dongle on it, and I can add Z-wave devices to it. It works good with Z-wave door sensors and other devices
Today I’m trying to add a Z-wave Lock to it. To support all the commands like “”Lock/unlock“” on the Z-wave Lock, I need to enable the security key in the option.xml, then click “Add Security Node” on the HA Z-wave GUI. And indeed, the Z-wave Lock is added, and is assigned with a new Node ID. But right after receiving a state change event from the Lock, HA crashed with a “Segment Fault” error. I tried several times, and this “Segment Fault” can be reproduced almost 100%. But if I remove the security key and reboot HA, it does not happen again. Anybody is familiar with that?
Is this the LEDE you’re referring to?
May well be that it won’t work on your hardware, or it may be a limitation of the LEDE platform.
Yes, it is a kind of openwrt. I think this is not a hardware issue. The only hardware is the USB dongle. And it works good with z-wave devices that does not require security key. It only has problem when adding a zwave device with security key like a LOCK.
I tried several times, when I uncomment the security key in option.xml, it will crash with “Segment Fault” when receiving a state change from the zwave device. Then I comment the security key, it won’t crash.
I suspect it is a bug in the openzwave lib that is used by homeassistant, which cause a “Segment Fault” when parsing a message from the zwave node.
Given that it works on other platforms, if it’s a bug in OpenZWave (OZW) then it’s only one that shows up on a limited number of platforms.
I’d suggest you raise an issue upstream, with the OpenZWave developers.
