Removed due to jhbroch’s attitude and Admin’s refusal to remove his petty post.
Apparently helping out a guy twice and then getting berated by him over not helping him a third time because he feels entitled and can’t be bothered to get to know the basics of Home Assistant is fine here but reacting to it is not… so guess it’s my turn to be petty then.
Thx again to those who helped me out! It was much appreciated.
This sounds like an interesting setup! Maybe use 8 input booleans helper with your rooms, and a script that cleans the rooms based on input select values? I believe if you name them something like, room_clean_xxx or something else that is easy to script I guess, adding removing and renaming rooms should not be too painful
First of all, you can’t use templates in a tap_action. So you will need to create a script, and then call the script. In the script you can use templates to clean only those rooms you want.
As suggested by @jeppesen you can indeed use input_booleans and name them smartly (eg input_boolen.clear_room_3 for the kitchen).
You could also use a mapping variable to map the input booleans to the rooms.
Great thanks for the info! Any chance you could share the code for your Eufy X10 dash design? Its almost identical to what i need and i can figure out the rest
Considering this is exactly what I’m looking for, I’m a novice, and people helped you by essentially giving you code - this is pretty unhelpful. I’ll figure it out myself but how hard would it have been to just copy and paste what you had.
