According to the documentation the Sony STR-DN1080 is compatible with the integration and I should be able to change input source with an automation. I have installed the integration and I can see the receiver in the entities list. I assume my problem is that I don’t manage to set up the automation correct.
My goal is to:
When press button A select input source BD/DVD
When press button B select input source VIDEO 1
Can someone please point me in the right direction or, even better, explain the steps from installing the integration to set up the automation rules. Am I missing something? Do I need to add something in for example the configuration.yaml?
Using HA on a Rasperry Pi
|Version| core-2021.11.5|
|Installation Type|Home Assistant OS|
|Development|false|
|Supervisor|true|
|Docker|true|
|User|root|
|Virtual Environment|false|
|Python Version|3.9.7|
|Operating System Family|Linux|
|Operating System Version|5.10.17-v7|
|CPU Architecture|armv7l|
service: media_player.select_source
source: VIDEO 1
device_id: idontknowyourdeviceid
Regarding most recent comment in January, that GitHub page is also linked from the Sony Songpal integration page, but the relevant link is toward the end of this quote:
Services
In addition to the general media player services, the following services are provided:
Service songpal/set_sound_setting
For a list of available settings and their values use songpal sound command.
Unfortunately, as should be clear from that link, where the songpal sound command is in a separate section from the songpal zone command, zone controls aren’t sound settings. AFAICT, someone would need to write a “songpal.set_zone_setting” service or something along those lines in order for us to control Zone 2.
