I write a addon and now I want to create repositories/packages.
I have two branches main (production branche) and addon (develop branche)
I have have managed in the workflow that publish the repository to add the branche-name as a tag.
But I get an error in de supervisor when I specify the tag in de image-line in config.yaml.
For instance:
image: “ghcr.io/corneel27/dao-{arch}:addon”
is not accepted: 2025-05-08 22:49:45.603 WARNING (SyncWorker_3) [supervisor.store.data] Can't read /data/addons/git/325af97a/dao/config.yaml: does not match regular expression ^([a-z0-9][a-z0-9.\-]*(:[0-9]+)?/)*?([a-z0-9{][a-z0-9.\-_{}]*/)*?([a-z0-9{][a-z0-9.\-_{}]*)$ for dictionary value @ data['image']. Got 'ghcr.io/corneel27/dao-{arch}:addon'
The regular expression seems to have some bugs, the / characters at columns 34 and 62 need to be escaped to work.
But, even if you fix the regex, it can capture only the string “ghcr.io/corneel27/dao-{arch}”, without “:addon”.
Thank you for your response.
Do you have any idea how I can select a repository with a tag in the image-line of a config.yaml or otherwise: how I can attach the branche-name in the name of the repository?
Ok, now it’s clear.
I don’t know how the github automation works. But the regex used to select the repository cannot accept the branch, it can only accept the repository. there may be present an option, in the yaml sintax, to select the branch.
