— edit—
of course i had to add the definition of my switches being a switch. duh…
- name: Opstaan
entities:
switch.sw_espresso_keuken_cl:
state: on
- name: Aan de slag
entities:
switch.sw_office_cl:
state: on
etc.
Still, i need some pro advice here, regarding checking the initial state of the switches, and how to smoothly switch between scenes. or other useful suggestions of course
— end edit—
HI, please send me in the right direction with this, i can’t figure out where to start, since all separate files give a green Yamllint, but various errors in the log, stating the switches aren’t allowed in scenes. Which is kind of troublesome, cause they’re the only switches i have …
2017-11-24 17:21:52 ERROR (MainThread) [homeassistant.config] Invalid config for [scene]: [sw_espresso_keuken_cl] is an invalid option for [scene]. Check: scene->states->0->entities->sw_espresso_keuken_cl.
switches are defined as follows and working perfectly, as a switch that is, not yet in the automations:
sw_office_cl:
friendly_name: 6 - Office
command_on: >-
curl -X POST -d ‘{“seq”:1, “method”:“object_prop_set”, “arguments”:{“oid”:“430ba8cf”, “prop”:“command”, “value”:“on”}}’ http://ip/iungo/api_request
command_off: >-
curl -X POST -d ‘{“seq”:1, “method”:“object_prop_set”, “arguments”:{“oid”:“430ba8cf”, “prop”:“command”, “value”:“off”}}’ http://ip/iungo/api_request
command_state: >-
curl -X POST -d ‘{“seq”:1, “method”:“object_prop_get”, “arguments”:{“oid”:“430ba8cf”, “prop”:“state”}}’ http://ip/iungo/api_request
value_template: >-
{%- if value_json.rv.value == ‘on’ -%}
{{ true }}
{%- else -%}
{{ false }}
{%- endif -%}
i then follow with some scenes:
Scenes
- name: Opstaan
entities:
state: on
- name: Aan de slag
entities:
sw_office_cl:
state: on
- name: Tv kijken
entities:
sw_audio_auditorium_cl:
state: on
sw_office_cl:
state: off
- name: Uit huis
entities:
state: off
sw_office_cl:
state: off
state: off
- name: Naar Bed
entities:
state: off
sw_office_cl:
state: off
state: off
a selector in an !include file:
scenes:
options:
- Opstaan
- Aan de slag
- Uit Huis
- Tv Kijken
- Naar Bed
initial: Naar bed
icon: mdi:home
and the automations:
- alias: Opstaan
platform: state
entity_id: input_select.scenes
to: "Opstaan"
service: scene.turn_on
entity_id: scene.opstaan
- alias: Aan de slag
platform: state
to: "Aan de slag"
entity_id: scene.aan_de_slag
- alias: Tv kijken
platform: state
to: "Tv kijken"
entity_id: scene.tv_kijken
- alias: Uit huis
platform: state
to: "Uit huis"
entity_id: scene.uit_huis
- alias: Naar bed
platform: state
to: "Naar bed"
entity_id: scene.naar_bed
