Select TV Channel with Android Remote
Trying to add a Couple of Favorite Channel Buttons to My LVGL Display,
but not getting the Service Call Right in the YAML.
I have Confirmed that this works in the Developer Tools:-
service: media_player.play_media
  entity_id: media_player.ai_pont
  media_content_id: "80"
  media_content_type: "channel"
It Successfully changes the TV to Channel 80.
But missing the mark on how to get the similar action in the LVGL.
Have Tried this:-
                  on_click: # on_press Triggers Immediately, on_click Triggers on Release if within defined time frame
                    - homeassistant.service:
But it Won’t Complie, Giving this Error:-
                  on_click:
                      Must contain exactly one of service, action.
Have Tried a few variation, but haven’t cracked it yet.
I get the impression that the entity & other data need to be separately passed to the media_player.play_media Service.
Can Anyone point me in the right direction?
Thanks.
This is another variation I’ve Tried:-
                    - homeassistant.action:
                        action: media_player.play_media
                        data:service:
It’s Error is:-
                  on_click:
                        [target] is an invalid option for [homeassistant.action]. Please check the indentation.
You should probably read the docs a bit more - but for home assistant.action: , target: is NOT in the list of actions.
Try this - but read the docs and examples first. Not tested so still could be wrong:
I’ve Since got it Working with this:-
                          media_content_id: "56"
But did Just Test your Example:-
And it Works as Well,
So both are Valid Solutions.
Service was renamed to action last year. Both are supported & mostly interchangeable, but if you want to future proof, I suggest you get into the habit of using action.
Great,
Thanks for the Heads Up.
Was Struggling with the Difference between Service/Action.
