Selectattr Problem
Hello everyone,
i have this code
{%set Lijst = states
                         |selectattr('domain', '==', 'media_player')
                         |selectattr('entity_id', 'search',Plaats|lower)
                         |selectattr('entity_id', 'search', 'sonos')
                         |map(attribute='entity_id')
                         |list
                         {{Lijst}}
that gives this result
['media_player.living_sonos', 'media_player.living_sonos_2']
But I would only have the media players with sonos in them, not the_2,_3,_4, etc.
Is this possible? if so, how?
Thanks in advance
{%set Lijst = states.media_player
|select('search',Plaats|lower)
|select('search', 'sonos')
|reject('search', '\d')
|list
{{Lijst}}
Thanks for your response.
This works
Can you explain it to me a bit?
The search test used in select and reject filters uses Python regular expressions. The expression \d will match any digit, since this is in a reject filter, any entity ID that contains a digit is rejected from the final output.
Thank You :+1:
